Diablo Trinity worth it?
miles5241
Buddy of mine is looking to sell his Trinity T-1000 for $200. Question would this do everything the Intune would do? and should I go ahead and do it and contact Lew to get a custom tune?
Right now its married to a 05 mustang which he will be selling next spring, he would of course un-marry it first.
As far as tunes they are the same I posted a thread on this already. Basically the trinity has better color on screen bunch of gauges in it and that's the main difference go on there Web site you'll see it all but for 200 id do it
Sent from my SM-G900W8 using Tapatalk
