Woke up to missing wheels and tires
Glad it it getting taken care of!!
Sux man i dont ever want to know what this feels like but cheer up bro!!! Once you get it all back give it a good long hand wash, Detail the intirrior and wax it.
Sent from my SM-N910V using Tapatalk
  • Replies 85
Just a little off topic, BUT... I did some work for a lady that had a security system at her house. I don't remember the brand, but she got it at Sam's Club. It would send her a text message within a couple of seconds if there was any "movement" that triggered the motion sensor part of the system. The text message even had a snap shot showing what was causing the alert.
She would literally meet me at the side door before I had time to walk from my truck to the door. While we were working, she disabled it to stop the constant alerts.
With all that said, a system like that would give the home owner a chance to meet the nice group of people that were shopping for upgrades for their trucks... :M16:
I think a set of cheap motion activated lights go a long way.
Sent from my Note 4 on Tapashit
That was done while the truck was on the jack stands waiting for the new wheels to arrive. I don't send a dirty vehicle in for service or repair.
Another wash with the new wheels and tires to cheer you up haha.
I was there when the wheels arrived. They were cleaned and got a coat of Poorboy's Wheel Sealant before they were installed. But, I did not wash the tires. I guess I will give them a good scrub when I do eventually get the truck back. :)
Glad you are getting fixed up. What are you planning to do to keep it from happening again? Park in a different spot? Alarm?
It's my driveway, so I don't exactly have a different spot to park in. I will be adding a motion light in the immediate future. Maybe some cameras down the line.
So is there a solution when you're not at home? Multiple different wheel locks on each wheel or what? I'm shopping for new wheels and don't want this to happen to me, and don't want to file another insurance claim thanks to my wife using up a few claims. I guess I'll start with multiple different wheels locks. Any suggestions?
4 wheels, 6 lugs per wheel,...use 24 different wheel locks. That should give you an extra 5 minutes or so. Or maybe I should say slow them down by 5 minutes at the most.
Why does everyone say it doesn't even slow them down? Do they carry a set of keys with them or what? How can a criminal completely ignore a wheel lock?
So after a little research, I found that you can add a shock and tilt sensor to your factory alarm. If the thieves have to hammer their lug nut key on your locks, it will set the alarm off. If they jack your truck up to take the wheels off, the alarm will go off. Now I just gotta find where to get this, along with those 24 different lug keys!
Do a search for: wheel lock removal socket
I have had to change a tire with the lock missing on the side of the road. I drove a deep well socket onto the lock using a claw hammer. Took an extra 30 seconds at the most.
So from what I'm gathering you just take your wheels off every night and leave them in your front yard for the guys. Wheels locks don't work. Gotcha.
    RyGuy43
    RyGuy43
  • Who's Online   2 Members, 0 Anonymous, 405 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
