everything new wont start
new starter, new battery. overhauled transmission. Before putting in tranny started engine running fine. Put transmission in and nothing, not even a click when turning key. Any ideas. Soon please. Really frustrated after all the new parts and work!
Can you turn the fly wheel in neutral
Sent from my HTC One_M8 using Tapatalk
Also check your neutral safety switch circuit system since you changed the transmission it might be out of adjustment or a wire got broken off in the R&R process.
All great idea's but without knowing the truck it will be hard. Follow the previous suggestions and also the ign fuses, starter fuse and then the ignition switch. Good luck and let us know what happens. You didn't change the EMC by chance? or use a earlier or later transmission?
