Amsoil?
Jbirch
Anyone have experience with this stuff? My buddy who's a GM mechanic said its good stuff and ordered me some through another guy. He said it was good stuff and was interested to see how it performed after the next oil change.
  • Replies 35
I feel like a post whore today, I obviously missed the forums while on vacation.
I run Amsoil Signature Series in my truck. I haven't had any analysis done on the used oil, but it seems to be working great, as my truck still runs[emoji14]
Sent from Tapatalk App - Samsung S6
I run Amsoil Signature Series 5w30 in my Cruze. Over 36k miles and the dipstick looks as clean as the day I bought it so I'd imagine the inside of the engine looks that way too. Seems to be great oil.
Thanks for the answers fellas. I have heard that it runs cooler. I heard people say it makes the truck more fuel efficient and blah blah blah. I didn't buy my truck for fuel mileage though. Hence the lift and 33s?
I run Signature 10w30 in my 2500hd (I have an 8.1l not exactly a fuel sipper), and it runs well. Doesn't burn nearly as much oil off as other oils do
Sent from my Vortec-powered Droid Turbo using Tapatalk
Up until this point I've been considering the Mobil 1 that everyone is seeming to go with on here, but now I may have to give this stuff a shot instead.
Been running Amsoil Sig 0W20 for about 6 months. Just did an oil change around 6800 miles. Filled it back up with the same stuff. I also sent an oil sample to Blackstone, will be nice to compare to when I was running the dealership stuff.
This stuff?
Please share your results with me when you get them :).
I haven't sent anything off to Blackstone with the Truck yet. I did on my previous vehicle, it was fun to see how levels changed when I switched from RP 5-30 to Castrol Edge 0-30.
Will do!
I run it in mine. The signature series. Its about due for a change, unfortunately since i moved for work i dont know where to get some locally but i will continue to use it since it runs really clean.
Sent from my Note 4 on Tapashit
But i hadnt thought of looking local until i saw this thread lol
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 510 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
