MVI Video in Motion Add-on Module
No. If you open the link I've posted (twice), you will see this option is an add on module. No swap, no reprogram.
Ah, got it now. I didn't watch the video the first time.
When I ordered the CarPlay upgrade and video unlock, the new HMI module came with the video unlock programming (which is a different service than what you're looking at). I assumed that the link was pointing the the unlock programming service (which they also offer separately). The video clearly shows them installing a bypass module :thumbs: .
I can't speak to that module directly, but the customer service I've had from MVI has been excellent! Anthony is very good at answering specific questions both pre- and post- sale. He responds best to text messages, so hit him up. His cell is 919-995-9523 .
If you get it, I'd like to hear back how you like it.
I've emailed them and have a very detailed response, just a couple more clarifications and I'm covered from a technical side.
Why I'm looking at the module is:
-Being in Canada adds another element to the shipping exchange. If the module is lost or delayed in shipping, I'm SOL until a replacement is available.
-The exchange option ends up being almost double the price by the time shipping is added in. Also as I work out of town, the 48 hour turnaround for me to install and ship back might not be doable adding another element to it.
That said, I am still leaning towards the exchange option at the moment. But being a brand new (less than 50 kms currently) 2016, I'm apprehensive of possibly putting in someone else's old unit and need some clarifications on possible warranty.
Want your stuff to work 100% correctly in an OEM fashion? Get the HMI Swap.
ESPECIALLY on 2016's as it can actually disable factory features on those models as well as any Carplay/Android Auto Retrofits.
We will work with you on the shipping time that shouldn't be problem at all. As far as the core swaps go it has yet to be an issue and we check each one of them as they come in and go back out (with the latest software), also really isnt a warranty issue as they aren't serialized. If it were to fail dealer would replace it and with a copy of the repair order you'd get your programming again!
I ordered a unit from MVI the other day and I cannot wait to get it and install it! I have a 2015 but I will gladly post pics and or video if you want me to.
Well I guess that solves that. Lol. Thanks for the answers!
I know there is a week to couple week delay due to demand right now, is the delay on the 2016's the same or longer?
  • 4 weeks later...
Got my new smart phone module 2.0 in today. Install was pretty straight forward. Had a couple of questions and texted MVI for an immediate response to help me trouble shoot. The module is great. HD crystal clear image. Everything functions while vehicle in motion and maintains all the factory controls. Their new module will also allow you to add additional cameras to the truck and additional avi input. Overall I'm satisfied.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
