New OEM wheel flares for 2016 Silverado
  • Replies 55
I got them painted6db37a842fc04cd5bb47eea0ae894e89.jpg15b1c4d12ed89a96e52446b49cf5614b.jpg
Sent from my SM-G920V using Tapatalk
Looked good before but way better painted.congrats,good job what they charge you to paint them?
$300 to paint $50 to install and $50 to install mud flaps
Thanks for info,gives me a idea price to expect.
They are pliable. You could turn them in a circle before installing them. Bought them from Ebay. 307.99 to the door comes in a huge box.
I bought bushwacker oem flares and they were the hard ridged plastic and I returned them ,
I like the softer plastic ones like GM had on their earlier trucks
GM should really go back to installing these at the factory on all Z71 trucks, but this time put a wider wheel on it too with a better back spacing to help fill out the wheel well.
If you need any accessories, would love to help. We have couple of toys for you at www.eTruckGear.com and offer honest service ( with 100 % positive Amazon feedback we try hard to be there for the customer)
Stop by and take a look. Tonno Pro is a nice brand to look at. Not that well known but super quality and low price. We are also Weathertech approved, meaning warranty applies as opposed to purchases on Amazon. Don't like Weathertech? We have Husky or Maxliner. Amp Research, Thule, Warn, Rhino Rack. Will be glad to help.
  • 4 months later...
are these the ones from gmpartsdirect.com? Looks They look little smaller and sleek, i like.
Actually, they are Bushwacker, not the ones from GM. But they look good, just smaller than the ones from GM parts website. They sell the "rugged" look, which are bigger flare.
http://www.cheapestgmparts.com/gmc/sierra-2500-hd/19329547/2016-year/slt-trim/6-0l-v8-gas-engine/exterior-cat/fender-flares-associated-accessories-scat/?part_name=fender-flares-rugged-look
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
