Drivers side rear rattle
I am trying to target where this noise is coming from. It is only on the drivers side, sounds like it somewhere between the back passenger door and the rear bumper. I can only hear this when the windows are up and radio is off. It is not a clanking sound, but more of a muffled rattle.
I do have a level kit with rear 2 inch blocks installed and it may be in my head, but I believe I started to hear this rattle a few days after I hauled about 1500 ibs in the bed, but it could have been before that.
Has anyone else had a similar problem? Perhaps I need to tighten up the shackles around the block and the leaf springs? I do recall a thread about leaf spring slap but I couldn't find it.
I made sure to double check the rear folding seat, rear seatbelt wasn't causing this noise, also there is nothing in the bed.
Not a major issue, so if chevy cust service reads this, no worries. it would need to get much worse before I would consider going to the dealer
I've heard something similar, and been trying to track it down. It makes a noise when I am going over varied terrain and isn't constant. I checked the rear seats and the seat belt and I can't quite figure it out. For me, it sounds like it is coming from the rotating joint where the rear seat is connected. No solution yet.
yes I am right there with you. the odd muffled sound made me think it was the belt hitting something or the rear seat bumping up and down. I am going to crawl under there later this week(to finish the install of my AMP steps, didn't do the LED lights yet) and see if I can find anything loose.
I solved my issue. It was coming from the rear driver side seat joint, I was able to reproduce it by moving the seat up and down slowly and only a little bit to mimic driving conditions. I fixed this in an unorthodox manner, I simply lifted and slammed the seat down a few times. Figured it was not going to break because it has to hold a person, but after that I haven't heard it, or been able to repro it.
  • 4 months later...
Can you post pics of the source?
interesting, ill have to look into that
Did you solve yours? I have (i think), the same noise. Dealer said its my AMP steps but I don't think it is....they aren't touching anything and all connections are tight.
So for me, it was the joint in the bottom right of this photo, it was coming from behind the half circle plastic sheathing. A couple of lifts and slams down, the issue pretty much went away, if I hear it pop up again I just do the up/down of the seat and it goes away.
Exactly I have had the same noise last 2 trucks, you got to slam that back seat down good or it rattles.
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
