8 minutes ago, 20165.3Eco said:
I think it's pretty silly we are all chasing what is clearly a design/quality issue.
When the truck is quiet it's such a pleasant vehicle to be inside. When it ticks it is like someone is tapping an ice pick into my brain.
What’s pretty silly is that General Motors still has a customer base after selling so many of these ticking, clunking, rough riding bastards. I don’t care if this is fixed when I start my truck in the morning and I never have another problem. GM has blatantly ignored issues with bandaid fixes and I have no desire to give them another penny.
Hahaha.. Don't worry, we'll find it..
All i can say is I'm glad its not a complete engineering failure. I'd be really pissed if it was some kind of safety concern, or a mechanical disaster..
Our 2011 equinox! I'm so glad gm owned up to all the problems.
Basically had to rebuild the whole motor - after warranty.
Ha, I just picked up a 95% rust free 88 Dodge D250. It has AC and Cruise control and is pretty darn quiet inside/rides about as good as this truck. For about 3000-4000 bucks I can toss in a spare overdrive trans I have and add EFI with a freshened up 360. Should make 350-400 ft/lbs and tow pretty well.
5000 dollar truck that doesn't tick seems like a pretty good option right now.
Seems like we're getting close. I wasn't buying into the tick being related to temperature, but as summer temps have gone and it has been generally cooler, the tick has been less frequent. I swear it was constant all summer
So what do we know. Its not vaccum pump or catalytic converters. Must either be in trans, fuel systems, mechanical in top end, pulley or water pump. Still see pretty far away. Be easier to just replace truck lol
Just got this from a buddy at my local dealer. Looks like Chevy is aware and they are working on a fix. 755e37f30625975dbc3861b38619a283.jpg
This coincides with the tempirary steering wheel turn fix someone posted the other day. I sent this to my service manager on my truck to get his thoughts.
Thank you
Sent from my SM-G950U using Tapatalk
Ya i googled it and found this :
Bulletin Number: PIP5570
This Preliminary information communicates to the dealer a conditionwhere a tick noise may be present inside a vehicle while driving. This may be the result of a deformed or improperly seated steering shaft seal allowing engine compartment
Thank you
Keep us posted please!!!!!
On 9/19/2018 at 7:58 PM, Jonty711 said:
And this was the noise beforehand. It's not as bad now but still there.
YES! This is the noise!!
Sweet, thanks for posting this. I highly doubt it will be covered under power train warranty if this is the case but I am still going to try and get my truck in to document it before my PT warranty expires in a week.
This weekend I rotated my tires, while I was at it I pulled the inner fender out of the truck and tried to see if I could get a better look at anything on that side. Everything looked fine but I tugged around pretty good on the steering boot and my noise seems to be much quieter all weekend. Still there and acts the same with bumps but much quieter.
Side note, my truck just ate another bushing for the soft lower tailgate. The dealer put in a new one less than 8 months ago. I don't really load anything heavy on the tailgate. Mostly carry tools and ski gear on the weekends.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 209 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
