Sound system upgrades?
Any links to good threads on sound system upgrades other than the kicker thread?
TIA
- Cato
I'm adding an amp for subs, installing a lineout convertor, it's a semi upgrade lol
wee
I upgraded my 2016 SD using the stock bose premium system and added a JL Audio 13tw5, with HD 500 amp, subthump box passenger side under the back seat, jl audio digital converter with bass knob. The bose system is doing a great job on the mids and highs and the added bass to the stock bose sub have shocked several that is producing such a tight balanced sound. Super pleased. We did have to disable the active noise cancellation since I have the 6.2 but I have not noticed much interior sounds that it was cancelling out. My dealer installs the kicker version you mentioned and the install guys said it hands down plus outperformed the kicker setup. That my set up.
Sent from my Note 5 using Tapatalk
I installed the JL Audio Stealth Box after saving for a year and a half. I also used an 800W JL Audio amplifier with a bass knob. I also tuned my amp to the speakers. Something I learned how to do a long time ago. It's not competition loud but it's loud. I absolutely love it and everyone that's been in my truck have only complained to turn it down.
Anyone know off hand what size the door speakers are?
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
