3m scotchgard film
Has anyone used the precut vehicle specific 3m scotchgard film pieces? I'm wanting something to protect from rocks and bugs. I just wonder how hard the application is to install?
I've heard it's best to go to an installer but I don't have firsthand experience. I'm interested in the answer as well.
Another day in paradise[emoji631]
I didn't get the pre cut pieces but got it on a roll & applied it to the truck myself. Just have to trim it around the hood fenders & such.
Was it simple to do? Did you do it by yourself? Got a roll coming in the mail today just wondering if I should get help
I used the rolls to do my sill plates. It was very easy as long as you wet the paint with soapy water to move the film around to where you want it. When the water dries the film is stuck where you left it.
Wasn't the easiest thing I've ever done but it's a lot like putting on window tint. I did have help my brother gave me a hand. I did 12" back on the hood. Headlights park lights leading edge of the fenders. Also the a pillars 6" back on the top of the cab. Since then my brother got a new 15 volkswagen passat that we did & it turned out alot better. The more you do the better you get.
I just had a shop do my 2015 Sierra
  • Mirrors
  • Hood
  • front fenders (leading edge, approx 8" back from headlights)
  • painted piece below grill
I've done a few DYI jobs in the past, and I'm pretty damn good at it, but with big pieces like these, definitely get a shop to do it. I didn't want to tackle the huge painted piece nder the grill. They did such a good job, you can't even tell its 3M'd. it ain't cheap though. Cost me $700 CDN, which is about $500 USD tax included
I stopped by a local window tint shop and they cut me 5 strips off a roll of some kind of 3M paint protective film (may be exactly what you're describing here) and used it on my door sills. I have already scratched the paint getting in and out.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 440 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
