How loud will I be?
TheLPGuy
I would be interested in hearing a sound clip of it. I can't imagine it is enjoyable to drive and would irritate all your neighbors and anyone next to you. I may be getting old but next week I am getting an exhaust done on mine (3" Aero duals). I had an Aero 3030 side dump on my '05 and it was perfect. Little rumble and idle and opened when you punched it.
I'm going to have mine removed and 3" ran back to the muffler. I have a borla xr1 and mandrel 3" tail pipe. It was quiet until I put a factory 6.2 tip on it and a K&N intake now the exhaust seems much louder. I'll still run the 3 to replace the factory 2.75 lead pipe and remove the Cali cat. Will it make a hill of beans? No but it's my fvcking truck and I'll do whatever I please. Lol. I'll keep y'all posted.
Im looking into getting the xr1 any way you could post a sound clip? Also are you running a 5.3 or 6.2?
It's surprisingly quiet in the cab. Can't really hear much of it unless the window are down. Once I put the new part in I will do a sound clip. I can also do a cold start clip and a warm start clip of the current set up tomorrow.
Don't take me wrong, it is your truck so by all means the louder the better for you. I want some rumble but not something I can't use bluetooth on the highway with. I am still debating if want to try the Flowmaster super 10 or if that will be too aggressive.
GM did really well with noise cancelling inside the cab. If you don't want as loud as the video I will post the other option I suggest is leave all cats and resonators and just delete the muffler.
They will figure it out when taken in for smog. The 2 cats close to the motor are pre-cats with the back one being the main cat. I had one of the pre-cats fail and clog the main cat. All caught at smog. I'm a hot rodder at heart but I don't mess with smog if it's mandated to be on there. Better off putting high flow legal cats
Sent from my Nexus 6P using Tapatalk
My state doesn't do smog testing! It's a beautiful thing.
OP, hoping one day you'll consider long tube headers!
I wanted to delete the third cat on my truck too, but decided to save for the whole shabang. 100% satisfied with the results.
To be honest I really want them but there wouldn't be a way I could get the whole set up till next spring. I have no ambition to wait. I was going to go to the exhaust shop today but I'm trying to convince my self to wait by doing other truck projects today. Today's project is installing a CB radio!
what about high flow cats?
I'm pretty sure stock cats are high flow, but deaden the sound pretty well. The first two cats will catch the majority of the sound, so aftermarket cats might not be a bad idea if you're looking for more sound.
  • 4 weeks later...
I just did this, mines a 6.2 with muffler and resonator delete and honestly isn't that loud, idle has a nice rumble and on wide open throttle it is loud but not overbearing. I just did the third cat removal yesterday and on start up in terms of how loud it is it isn't louder but sounds a bit different, and crackles and pops on deceleration as well as sounds a lot better up high up.
There is no place in North America where a straight pipe is legal. Feel free to double check but I am 100% positive on this. I am also pretty sure you can get in trouble for selling a vehicle in CA without a CA cat, someone from CA can correct me maybe.
My 2c it just seems silly and a total waste. If you want louder in the cab you should get a Flowmaster Dual Out Dual side Super40+. This would allow you to remain incomplete compliance and probably make a much bigger impact for around 6-800 bucks.
Do what makes you happy though.
Off topic, but fun fact.
In some parts of Canada, including my province, the vehicle only has to be inspected when sold. Once it passes as long as owner ship doesn't change you can do whatever you want to it. I had a cat-deleted Subaru with a 3 1/4 inch titanium exhaust that was louder than some jets, that thing spit flames on down shifts. My current 05 sierra has no cats or resonator, just a flowmaster 40. We have almost zero laws surrounding modifications here :driving:
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
