2015 Silverado CC 5.3 SB non-Z71 Shock Part Numbers
Can someone with a 2015 Silverado Crew Cab. 5.3 v8, Short bed, non-Z71, non-Max tow pkg, post the part numbers for the front and back stock shocks? Looking to replace my Z71 Rancho shocks with regular non-Z71 shocks. Thanks!
Cheaper to go with Bilstein, better ride too. Went from non rancho shocks to bilsteins and the ride is noticeably better
I did the same thing to my 14. The ride was a little less jarring but still had the bouncing. I went with Bilstein 5100 on the third setting. If your not going to raise your front end any go with the Bilstein 4600. The Bilstein is a much better shock than the stock shocks and will cost less.
So how did the bilstein compare to your second set of stock shocks? I'm not a fan of the bounce but the jarring is personally more annoying to me.
The bounce is gone and I only have the bilsteins on the front.Have the stock black shocks on the rear. The 5100's are stiffer but the jarring is gone. I have the 5100's set on the third setting that raised the front end 1 1/4 inches. I think when you are compressing the spring more than stock, the ride is going to be stiffer. If your not going to raise the front end any your ride should not be as stiff. You can go with the 4600 for stock ride height. I have 20 inch wheels which can make the ride rougher also. Wish I had 17 or 18's.
