2014 Silverado headlight updated to LED?
As we are aware the headlights on the 2014/15 are not desirable... Looking at upgrades and a coworker suggest LEDs. He has used www.superbrightleds.com for his needs and it looks like they have high and low beam LEDS for our truck. Has anyone done this conversion? I'm interested to find out how it went and what you think about it afterwards??
  • Replies 32
I've got them in my 2015 silverado.. very nice bright lights had to cut the tabs on the caps that seal the high and low beams and switch them around.. only downfall is they interfere with the fm radio but I have xm so doesn't bother me
LED's will be brighter than the stock halogen lights but they are not as bright as HID's. Just helped a friend remove his HID's and put LED's in a 2014 silverado and they are not as bright or have as much down road visibility. I would say that the HID's he had were 25% brighter than the LED's but the LED's are 200% better than stock.
http://www.xenondepot.com/H11-LED-headlight-kit-p/h11-led-hl.htm
These are what I put in mine. I have no issues and no need to cut tabs as it is a direct swap with the stock bulbs
Did you get the ones with or without the CANbus?
That's what I was looking for... I realize the HID is best route but I dont have the $$$ or time to do that conversion at this time.
Just don't put them in a Halogen headlight, be respective of others...
Tyler
Stock is halogen in both projector and reflector h1 I believe for both. But yes HID and LED should not go into a reflector housing.
So will these not work well in the stock headlights that are on the truck??
They will, he is just talking about the glare and mismanaged light that hid creates when they are not focused correctly. It will work but usually if it's not a projector most of the light doesn't go where it should on the road.
I ordered the CAN-bus just in case, but installed without and everything, including the DRL's work as intended.
Do your drl's still function properly?
Yes sir
I have night-lux - low ,hi , fogs . and I love them . no problems at all
I just installed the new vled smz bulb (low and high) and they're bright as heck
I just installed the same set up but they keeping flickering and shutting off. Vleds said they have a drl module coming out in September to fix.....hope fingers crossed. They sure are nice and bright though.
Sent from my VS985 4G using Tapatalk
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 429 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
