Turning off your T/C
Has any ridden around with their T/C turned off and noticed a difference in their truck? I feel like my truck is more responsive and feels more like a truck. Is this all in my head or by Turing you traction control off give your truck a little more freedom to shift and what not?!?
There's a running theory out there that suggests that turning off both grade braking and T/C fixes your tranny shifting weirdness.
100% agree with both on the running like it should and shifting like it should
How do you turn off grade braking?
Sent from my Nexus 6P using Tapatalk
Press and hold your trailering button (end of shift lever) for 5 sec and release. DIC will inform you it is now off.
Does this have to be done every start?
It really does work. I've noticed a huge difference in the last couple weeks doing this, along with turning off the grade braking on the lever
Also for those that didn't know, if you press and hold your T/C button, it will also turn off stabilitrak... you know, for donuts in the wintertime :-D
That works until 35 mph or so... then stabilitrack comes back on and stays on..
Sent from my SM-G900W8 using Tapatalk
I noticed the same thing today, couldn't figure out why the stabilitrack would turn back on after I shut it off. I thought it had something to do with the speed but hadn't paid enough attention at what mph it kicked back on.
Grade Braking is also turned off when you are in Range Select Mode (Manual Mode).
every time i get in the truck my procedure is to put into m6 and turn off T/C. it could be black magic but with the afm delete the truck is better. dosent help the clunkyness of it just more of the trans getting confused part..
Afm delete? Sorry truck mod noob.
i have V4 mode turned off
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
