Vleds SMZ Bulbs
Looks like a brand new product from vleds, not the most lumen output but they make a quality product and figured for under 150 bucks why not. Should compliment my morimoto xb fogs pretty well. Certainly cheaper then buying a new truck...
On the webpage at the bottom of the details list it states "Not for use in low voltage high/low beam DRL applications." I'm guessing that means Silverados and especially Sierra's since one light is used for all three functions? You think maybe they say that so that the actual lights last closer to the lifespan expectancy they state?
Well, I don't have them yet (although I did get a shipping confirmation yesterday... Woop!) so I can't answer accurately. But I did put a volt meter on my truck the other day because I was curious. It read anywhere from 13.5v-14.5v. It read the same for both drl and the actual low beam headlight. So I'm not sure it will be an issue amigo!
Anxious to hear what you think of them.
Word to the wise: make the holes in the dust covers slightly above the exact center of them. Otherwise the cooling fins are being torqued too much from the cover and your grommet won't fit quite right. In the worse case scenario, you'll break the bracket that your h11 bulb locks into off the back of the projector housing. Not that I know about this or anything.... (I know all about it unfortunately) currently exploring options as to where I can pick one of those up. Having zero luck so far
We talking the same smz bulbs here?
These do not have a fan with heat sinks like the lmz ones do, they use that braided metal ribbon type cooling setup which i believe go through the supplied grommet and hang freely out the back of the dust cap.
Yeah, we're talking about the same bulb. Poor word choice on my part. But the hole still needs be a little more "north" on the dust cap so the cooling ribbons are free of obstruction and so the grommet fits correctly
Sorry should of noticed you posted multiple times in this thread already my mistake. Any chance you can snap a picture of the dust cap and the proper placement of the hole? Although i'm not sure how much difference there is between a silvy and sierra.
Absolutely amigo. Ill take pics tonight. High beam was successful. Low beam is the one broke that projector housing
Never got to my passenger side last night
Other than the hole placement issue you have are they actually plug and play? How are they for flickering, notice any? I just put switchback LED's for my blinkers now my headlights look really bad even with the whitest halogen bulb I can buy. Thinking these LED's for my low and high beams will get everything the same colour and hoping it'll be a little brighter too.
Still experimenting with the flickering with the low beams. I just put a black hat over my optic sensor and that seems to take care of it, but like I said, I have bigger problems than test that yet. As far as the brightness of the high beam... Holy cow. It's great. I go to work early in the morning when there's no traffic and got to test it. You're definitely going to light some things up
Yeah definitely get that bracket fixed before worrying about the flicker haha If you can't get just that part might have to get a new housing. I bought a pair off eBay fairly cheap. Well compared to dealer prices that's for sure.
