Nixonride's 2016 SLT 1500
NIXONRIDE
  • Replies 43
Some better pics of the new wheels/tires. Amp steps should be here tomorrow, hopefully will have enough time to get them installed. I also just received the Denali door handles, off to paint with the rear tailgate chrome handle.
3ADACC1C-7E7E-42F3-AE6C-E92F3C0CFB62_zps
E57B2305-A1BD-4F8A-A43F-62BEBD170D69_zps
6AE62B0D-0400-45C1-8B62-8ED6DAB98628_zps
5B3C736C-A640-4BC0-94DF-BFFC5AD9C8EB_zps
F5F2168F-2F49-45DF-973A-C6EFB587D5E4_zps
Greg you mention in your first post the addition of Blistein 5100's. Any difference in compliance over washboard like surfaces?
Not really... I do have some freeways that seem to have a cut in them about every 15 ft and at 60-70 mph you get a steady bounce...it actually annoyed me at first but once I put the 22's with the new tires it seems the weight of the wheels have diminished it somewhat. For the money they are way better than stock and I think of you don't lift them to the top you will be better off. I actually am considering the 6112's or some fox coil overs as I want to lift the front another 3/4 of an inch or so.
Well I fianally got the time to fully install the Amp steps...IMO it really helps set it off...now to trim down the air damn.
CC439E51-C7FA-4D84-AA23-187A4C7C50A2_zps
FF515DDD-F1AE-4C54-9BF7-6871C1F3C72B_zps
So a couple new updates over the past couple weeks.
1st off is the lit door sills...unfortunately the pics don't turn out to good, probably need to take them at night, but they are a nice little addition. Pics also show the new GM floor liners which are great!
ED8D0AB4-FE51-46B6-8641-AE5868E32AA6_zps
66CD8234-7210-48FA-A929-B3F16B259955_zps
37820A05-1DCF-4D8B-971C-CF6BB15F581E_zps
Newest addition is a little upgrade to the stock stereo. 2 audio mobile 10"s in a custom box/boxes that fit into the GM under seat storage tray. The sub box is split into two so I can remove one if I need the storage...probably not gonna happen but you never know.
5B5A70B2-706F-447E-8EA3-52CB20C2C5EF_zps
EB6497CE-FFEB-4AB3-ACA8-225D0EF71265_zps
526D0DEE-8C95-4A35-8FC0-B351320CF70D_zps
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
