Offsets wide stance
ZachZ71
Wondering if anyone here has a 2014 or newer with 20x12 wheels with neg 44 offset. Trying to find a good set up for my truck
I do. 20x12 -44 on a 2.5 level. You will have to cut your fenders if you're considering something like that. Just a word of caution.
Check out the wheel and tire set up thread. Almost 200 pages of exactly what everyone is running.
http://www.gm-trucks.com/forums/topic/161228-post-your-2014-wheeltire-set-up/
I would say the average for aftermarket wheels is between 9-10 inches wide. Many being 20x9, 20x10, 22x10 or 22x10. These are mostly on stock or slightly lifted/ leveled trucks. Now offset is a different story. Most people are running anything from a slightly positive offset to stuff bigger tires under the truck to a higher negative offset (-24, -44) to get the "stanced" look. Most common is a 0 offset or slightly positive I believe on most stock or leveled trucks. Hope this helps.
Interesting. I thought the negative offset was in order to stuff wider/larger diameter tires under a lift. Surprised to hear that you need positive/0 for that.
In that cast I really don't understand the negative offset at all.
  • 2 years later...
I have 22x12’s -44 on 35’s but you need a pretty good size lift to run without cutting into your bumper and Cali mod’n your fender to clear for turning radius. How tall are you going?
  • 1 year later...
