2017 All Terrain - Color Matching
I was poking my nose around a few websites looking at the 2017 All Terrains and noticed that it looks like GM has started offering them with color matched door handles, mirror caps, side molding along with black window molding and black round assist steps. Anyone seen this in person yet? I did notice on a couple of white trucks that the mirror caps were black though.
Picked up mine last week, everything is color matched except the mirrors, they are black on every color All Terrain..
Sent from my XT1254 using Tapatalk
Are they black as in do not have a cap at all? or does it have a cap it is just black?
The cap just pops onto the mirror you can tell by seeing of your mirror has a little indent where a cap would go and the be flush with rest. ie. like on a base model there is just no cap period.
It's a painted cap, just like the 14-16's had caps/albeit most of them chrome in those years...
Which makes no sense, if you are going to color match everything else, why not the mirror caps as well?
Agreed
Dang it, of course. I just got the door handles changed out on mine to white. Either need to have the mirror caps wrapped or else changed out. I hate the chrome on the steps as well, would of have liked the black steps as well.
Yep I love mine all color matched and the black mirrors with the black steps.
man looks like mine... i just got the chrome... either way i like the looks of both... still a sick truck....
Anyone able to get a part number off of those steps? If I remember right GM puts a sticker with the part number in one of the hollow hangers. I replaced the factory square chrome steps on my 2016 with the factory square black ones but I think I like those on the 17's better.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
