Display mode (day / night)
I believe I have a similar problem on my new '17 that I am currently in "discussions" about with my dealer.
You said "On radio display screen - under setting the display is set to day mode"
In my Infotainment manual, page 100, it says Settings -> Display -> Mode gets you to three choises: Mode, Calibrate Touchscreen and Turn Display Off. Is that what your display shows? Mine only shows two choices (Calibrate Touchscreen, and Turn Display Off) and always acts like it is in Auto mode. Please let me know if I understood your post correctly. I'm getting real tired of the display dimming every time I drive through a shadow. Thanks.
You might want to double check on the 1500 forum as I don't believe anyone here has a '17 HD yet. Assuming software is slightly different.
A reasonable suggestion, but I have already had the dealer check two other '17 1500's equipped like mine and they exhibit the same problem, so the problem is systemic to at least those trucks. I was trying to see just how wide spread (model, year, radio) the problem was. Would you mine telling me which infotainment system you have (7"/8", Nav/No Nav) and if you can control the brightness mode (Auto, Day, Night) of it? Thanks
My '16 is the same as yours, calibrate and off as my only available settings.
  • 1 month later...
All if this has been done before I posted. None of it works and the dealer can not duplicate the problem. They say it must be the software and needs reprogramming. Go figure. It is irriating for the radio and the dash to just go dim during daylight. I will eventually go back to the daylight settings but it takes some time. GMC needs to address the problem.
Dealer could duplicate problem on their vehicles, but . . . GM final resolution: Miss-printed manual, working as designed. :bs:
  • 1 year later...
Has anyone had the issue where under display settings where the two options :
1) calibrate screen
2) display off
You select the off option and the screen turns off but comes back on after 15 or 20 seconds. I like to be able to turn the display off while driving at night but for whatever reason its not staying off...
I do turn down the dash dimmer as much as possible since it greatly improves the night time visibility (when away from town lights)
I wish it could be turned down further.
(my recollection from 'back in the day' was that the dash lights could be turned off completely if desired)
My other pet peeve is that with it set the way I want for rural night time driving, it won't be bright enough for daylight.
It should be smart enough to save as setting for when in daylight mode and a separate one for when it is in night mode.
I also would like to be able to turn down the backlight on the steering wheel controls.
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
    • @OnTheReel , What oil was used for this sample?
