Gearing 308 VS 342 What?
Totally agree.
I test drove the 3.08, floored it up to about 70 mph - then I got out of the 3.08 and into an identical truck with the 3.42 and drove it the same way. No difference in acceleration whatsoever. I bought the 3.08 and have no regrets.
Us 3.08 guys can brag about how when passing, it gives an increasingly nice pull after 60mph, all the way to 100 if you let it.
  • Replies 67
Ours pull nice when passing too, all the way to 100 if we let it..lol
But with a trailer hooked up to the same truck we can still pass traffic very easily..... Yours on the other hand suck terribly for both passing or negotiating hills and such with the same trailer hooked to it.....
It's one thing to talk about a vehicle by itself, it is quite another when you add weight to it! Please Stop misleading people until you have done both. Imho
I have a snow plow on mine and it pushes and piles without issue. I've towed heavy loads and the only thing I noticed was my fuel gauge drop about 3 times quicker than normal - but I am not looking to race anyone while I have 6000lbs behind me once or twice every two years either.
3.08 is in no sense a slouch. No way is there such a vast difference between the two as people like to say. I couldn't be sure till I test drove them back to back, but I found zero difference when I did.
I had a 2016 Silverado 1500 LT with the 5.3 and 3.08 gears. Was very good on flat roads. I drove to Ohio from Virginia and struggled horribly on the turnpike and didnt do too amazing in Ohio, itself. I traded it in for a 2016 Sierra 1500 SLE with 3.42 gears. Made the exact trip, and averaged(if memory is correct) 21.9 miles a gallon. The Silverado only averaged about 19.3. Not a HUGE difference, but still. I've noticed my gas mileage is way more consistent with the 3.42 gears. And for what I do tow, i have noticed the truck does not struggle with the gears like the 3.08 did. The 3.42 seems like it has more bottom end "grunt" than the 3.08 does.
Allways get the highest available (numerical) ratio possible, makes a much better driving truck.
I just got a '17 max tow 6.2 that gives it 3.42.....but wish the 3.73 was possible. but 3.73 is only 5.3 max tow
Apparently, everyone else who has done real mileage and various terrain both, and pull (more than 2 times a year and not on flat ground) prefer the 3.42 and 3.73 gears over 3.08 and 3.23 hands done.
And we don't even have to floor it, to make it "not a slouch" I can assure you we are not racing it nor do we wish to have to use 3/4 - full throttle to get it to move decent.
Holding gears on hills with out it downshifting all the time is also very important when it comes to towing, something your 3.08 can't do very well unless you are in a lower transmission gear already, at which point your gas mileage just got a lot worse on that 600 mile trip.
By the way, I hope you are not plowing that heavy snow so fast that you are getting up to 6th gear.....;)
It isn't significant, it is about as proportional as the mpg. Case in point, C&D tested a 4x4 Silverado with the 5.3 and 3.42 as well as a Sierra 4x4 5.3 and 3.08 (both loaded crew cabs). Silverado was 4 tenths(0.4) faster and 1 mph quicker through the 1/4 mile but 2 mpg behind in testing. 1 mph on the big end after a 1/4 mile isn't significant and neither is 4 tenths (roughly a truck length or truck length and a half depending on who you ask).
I always crack up when people say the 3.08's are a dog, bet you blind fold them and do a full out acceleration they would not be able to tell a difference between the two.
Tyler
As far s .4 seconds in a quarter mile goes. If you are both going 90 mph that's about 135 feet per second. The truck with 3.42 would be more like 3 truck lengths.
3.08 are great for those in flat lands, low towing demands and mileage. I've driven one or two, and honestly, they are not all that bad. The 3.08 trucks pull strong beyond 55 for sure. But, if you have hilly lands, higher towing/payload demands, the 3.42 is always worth the box check. Lot less lugging of the engine. But...then you get in an HD truck with the 6.0, and you feel the pull of those 4.10 gears...no looking back LOL.
Ooh yes 4.10's!!!
Had them on a 99' 1/2 ton pulled the trailer great, but the daily gas mileage on that one was alot worse than the 3.73.... But i liked how it held the gears better:)
Big difference if you haul or tow, if not it's probably not a big deal but. I'm talking 6 speed trans of course. Its about 3k of extra towing capacity which is a big deal to me.
3.42 has significant increase in acceleration with seemingly the same mpg. I've paid close attention to everybody's mpg posts, and I see no difference in the 3.42 compared to other ratio's.
I was surprised how much of a benefit it was, if I was ordering a new truck it would absolutely have 3.42
Having had both in similarly equipped trucks this is what i gather as well.
3.08s on 33s felt like a turd but had amazing top end once the engine mods went in.
Current truck with 3.42s feels much lighter off the line, have yet to see how large aftermarket tires will affect it but i will find out soon enough.
Sent from my SM-G935V using Tapatalk
I'm sure larger tires will hurt it some, but it may still be fine depending on the size.
There comes a point though when the tires and lift get big enough that it will be a turd, which is why people regear.
It's also why they automatically bump up the axle and ratio on the max tow package, because they know it works better for the use of the truck...
    • FYI, I used sq body headers on my 72 and they were a perfect fit with zero clearance issues with the rods and Z bar for the clutch  I agree with post on worn mount rubber
    • I do most of my yard work before 10. My summer walks are usually at Kroger’s. Inside and yes I’ll do light shopping. Usually by noon you don’t want to be outside from June to September. The mail box is a good walk. I’ll walk there about 3 times before the mail comes. My house has two floors if I feel I need to move I’ll do the stairs. I’ll walk down the lane to our rent house with clippers trimming branches along the driveway. There’s always something to do.
    • There is a sign at my chiropractors office that says, "Don't quit, take a break." Sound advice.    On a 65 degree day (F) I can still work pretty darn hard (I'm 72). On a 85 degree day with a good deal of humidity it takes me three days to do what in took at 65 degree in three hours. If I work to muscle exhaustion (back) it will take me days more to recover. Taking breaks to prevent that is most useful. A lift belt has been very useful in preventing both.    Minister was giving a talk the other night where he was speaking of age and he used a clock to illustrate the human lifespan and it's ability to task. 1 to 45 was the second hand, scurry about. 46 to 70 the minute hand. Slower but...71 and up the hour hand...Hummm....until that talk I felt more like the minute hand. 😭   Then he says, the most useful hand on the clock is the hour hand. Without it you can't tell time. (Hour of the watch). I felt a bit better knowing we over 70 are useful. 🥹
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
    • @newdude great info, thank you!   So opening the thermal bypass valve early (or all the time) would cause temperature to rise more slowly, but above 194F there would be no difference from normal operation?   It seems like the only practical ways to bring down the peak temperature would be to improve the oil-air heat exchanger in some way or increase fluid capacity?
