Looking for help
He is looking at a GMC SLE, which had the crap headlights.
After looking at the link the OP posted, I personally would pass. A 2014 with 80K miles should be priced less in my opinion ($27,995). Put another $10K and get a new truck with a full warranty.
That link he gave goes to an SLT and he says in a later post that he is looking at the SLT so it is probably more like 15k more (43kish) to get into a comparable SLT.
Ok I do appreciate all the replies, all have been helpful. So the more I looked at theses trucks I found a 30k mile 2015 SLT crew being sold by the original owner. Truck is awesome. Carfax is clean. Owner says no issues. Reading these forums I'm scared as hell to pull the tiger and buy any gm truck 14 thru 17. Are they all really that bad? Headlights, vibrations? WTF? Don't like ford's or dodges but maybe I need to look there instead.
Do you know why he is selling it already? I have like 37k on mine and it has been great. A few issues arose and were taken care of under warranty swiftly. If you go the Ford or Ram forums you will see people have issues with those trucks too. Any thing that is mass produced will have some flaws.
Story is the company he works for gave him a nice company truck. Didn't need this one filling up the garage and insuring. I have no reason to doubt his story. I drove it ran it up to 80 set cruise, ran it up and down a little, all seemed good.
But reading the section on vibrations, some of their issues didn't surface until around this amount of miles on the vehicle. Just trying to understand if these issues are across the board or isolated to certain models. :nonod:
AND 80,000 less miles.
If you have taken the truck on a test drive at 80 ish and all is well i would bet it is good to go. The problems largely discussed on here usually creep up before 30k miles. If you have a contact in gm service you might be able to have them run the vin and see any and all service/complaints with the truck. Also maybe ask the seller to allow you to have it looked at by a service department on your own dime, they could easily look up history then and give you a clean bill of health.
AND THE BIGGEST SUGGESTION I CAN GIVE YOU IS TAKE EVERYTHING YOU READ HERE WITH A GRAIN OF SALT. IT IS A VERY SMALL PERCENTAGE OF TRUCKS BUILT.
GOOD LUCK.
smrr1,
Thank you, that is a great suggestion of having it looked at a dealer service department.
"AND THE BIGGEST SUGGESTION I CAN GIVE YOU IS TAKE EVERYTHING YOU READ HERE WITH A GRAIN OF SALT", Yes, I believe you are correct.
"IT IS A VERY SMALL PERCENTAGE OF TRUCKS BUILT.", Thank you, great to know that.
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
