Looking for a Mid Travel system that fits my needs
JasonAVGuy
Hey everyone I could really use some help with my suspension. I was playing around on a millings pile the other day and I am really unhappy with the travel of my front suspension. I have looked at a ton of kits and feel I need some help and opinions of others. I use my truck every day on and off road. I tow a good bit and it is my daily driver. I would like to keep my 17in gm rims with 285/70r17 and also be able to put my stock 18in rims on the truck. I'm looking for a kit that gives me more suspension travel and 2-4 inches of front lift. I also want to maintain the rear rake because with my decked system and tools in the bed my truck sits level. Being able to still tow without issues is a must for me and maintaining drivability is important. I do not want to add front spacers or just level the truck my goal is for more travel and more front bumper ground clearance.
Truck On rocks
Suspension Flex 3
What I'd recommend is what I'm doing to my truck, I'm getting the Icon suspension kit, it's a longer than stock travel suspension and since it's a coil over in the front it's adjustable from 0-3" of lift, from everywhere I've looked it's going to give you the best daily able set up and is going to fit all my needs which are much like yours, the only difference being mine has 20's, if you want to maintain a bit of rake to be able to put stuff in the back and tow I'd recommend adding a leaf in the back, it's what I did and it added the right amount of rake. These trucks look nose high when they are perfectly level so that inch or so of lift the leaf adds makes it look level
Thank you! I will take a look at the Icon kit. I am planing on adding helper springs in the back as is so I may end up adding a set of rear blocks to help. My decked system adds about 500 pounds of constant weight.
You could go with the bajakits chase kit, it includes king shocks and UCAs, deaver springs with bajakits shackles are awsome.
Im not sure on the amount of travel for the front with the chase kit but i get 12" on my bajakits prerunner kit with 4x4. I think its 14" on 2wd
The chase kit allows you keep the swaybar and stock fenders for stock width
The prerunner adds like 3" per side so you will need fiberglass fenders.
Do you know if the chase kit adds any front lift? Also I can't seem to find out if you can keep the stock rims. Any thoughts on the chase kit vs the camburg kit?
https://camburg.com/shop/suspension/fox-chevy-1500-2wd-4wd-07-14-factory-2-5-kit/
It will lift the truck since youre bolting a longer coilover
Honestly i would go with bajakits over camburg, i feel camburg is more commercial and uses round tubing for the UCA
Bajakits is a sidebranch for brenthel industries, they race and build their own trophy trucks and all sorts of buggies.
It seems like camburg works with fox and bajakits works with kings, i guess its a matter of taste
Theres a guy here selling brand new bajakits UCAs
As for the wheels, i dont know on bajakits chase kit but on my prerunner kit i needed 4.75" backspacing, idk what stock wheels are
Camburg also requires 4.75"
Thanks! You bring up some good points. I never thought about the round uca's. I liked the idea of the camburgs because of the lift but I would rather have known quality. I guess I need to figure out if my wheels will work.
Both Baja Kits and Camburg have racing backgrounds. As far as Upper control arm build materials, it really comes down to preference weather you want to see tube or boxed. In this application there is no advantage/disadvantage between the two.
Both are going to give some form of lift, up to about 3"- The lift comes from the Coilover, the upper control arm eliminates ball joint issues from the added lift height and the uniball helps smooth out ride transition bump/full extension.
Stock wheels will work on both, but you will run into rubbing issues with an aftermarket size tire.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
