new from Ga
DaveHC
Just bought a 2017 High country 4x4, traded in a 2015 Ram big horn that I had for 14 months. My previous truck to the ram was a 2000 Silverado ext Z71 that I drove for 16 years and had 232k on it when I sold it. Ram was ok but had some issues so got a good deal on the chevy and traded.
