Mirror cap removal 14+
Klutch
I know there are some threads on this but has anyone ever found a good way to get these caps off WITHOUT breaking the tabs off? Nearly everything I've found says "but I broke a bunch of tabs off". The big problem I have is I bought a set of power folding mirrors that had chrome caps. I want to get the white ones off my originals and switch them, preserving all caps for 2 complete sets of mirrors but all the caps are current on so I can't even see what the clips look like to formulate a plan of attack.
I have pulled 2 sets and have yet to get a set off without breaking the tabs. Last time I did look the cap as I put it on, I think (I have not tested) that if you work your way across the top of the cap and lift up it will release the top clips, the allow you to rotate the cap backwards to get the rest of the tabs to release.
When I did mine, I didn't have issues with the caps. If I recall, the tabs were towards the top. I used the plastic bezel removal tools and gently worked my way around.
IF they're the same mirrors with just different caps why not switch out the entire mirrors. More work but seems a lot more safe so you can sell the extra set.
Pretty sure he bought the dl3 mirrors and he has the dl8. Wanting to put his old painted caps on new power folding ones.
cbrsilv15: That's exactly the case. Does anyone have a good, clear photo of the underside of one? Nearly all the photos I see are obviously of the outside of the cap.
Thanks HoosierZ, I've seen your video but it really doesn't get into the specifics of safely removing it or really no mention of if it's going to be destroyed in the process. If they were black work truck caps I wouldn't care and just tear them off but I really need to preserve both sets. Anyone have a good photo of the underside?
I typed in 2014 silverado mirror caps on eBay and there are a bunch of pics of the back sides if that helps. Pain to upload it to PB and then repost here.
Hmm.. I did find a pretty good set to look at, thanks. So do the tabs at the top have the metal sharkbite type clips on them that go into a slot? Then the bottom tabs just slip over a ledge. Looks like there are 3 on the bottom/outer edge, then 2 up top?
Well, I went ahead and took a stab at this. Doesn't seem to be much choice than just to hope for the best. I did manage to only break 1 tab on each cap, both the chrome and painted. I did break the big looping hooks in the center of the cap on the chrome ones (assuming they were on them like my painted had). Think the only thing I'd advise someone that might find this thread to do is to wait until a hot, sunny day and let it sit out for long while. It might make everything a little more pliable. It's cold where I'm at and cold in the garage. Putting heat on them with a gun might have helped.
The odd part was they go on with MUCH less drama than coming off. I'm still not convinced they're on there all the way. What sort of tape did you guys use? I still saved a clip on each one but might pull them back off and get some tape under there. It'd suck to have the cap blast off at 80mph
I found that using the Tapatalk app makes uploading photos easy. Hate having to use the computer to upload photos here.
Not sure why this seems so hard for some people but I followed the instructions and pulled the caps off without breaking any of the tabs, in fact I popped them back off and then back on no problems. And who gives a $hit if all the tabs are broken....just use double sided 3M and your good!
RT
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 573 Guests (See full list)
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
