Bed mats for 2015 and up
John Dell
Has anyone found a rubber or similar bed mat for the 2015 and up standard bed? I bought a rubber mat and it was labeled 2007 and up. The 2007-2014 box is 6'6". The new 2015 and up is a 6'7" box. Everyone I talked to said they use the same part number for the new trucks. So I tried one and sure enough the mat is a inch short up front. Otherwise it fits but I want one that fits correctly and won't trap small things up front or get under the mat.
GM liner is the same as the 2007-2014 trucks all the numbers carry over. The internal box measurements, design, load points, and some inside sheet metal are the same as GMT-900. My 8' fits no issues at all.
I have looked at the GM version and the bedrug and talked to them, they spec it at 6'6" so I am assuming it will be an inch short.
The 8' box may be the same but the standard box is 1" larger.
Bought a generic one from Tractor Supply. It was labeled something about being for GM trucks up to an 8'. It simply needed to be trimmed.
I have the DeeZee mat for 07-16 and it is approx. an inch short also. 1/2 up front, 1/2 in back. I was under the impression it was to keep the front drain holes un covered.
The mat works good for me. It does not let stuff slide that's for sure.
I put in a Bed Rug. My 2016 Denali HD had a spray in bed liner. I got the 3M packets from Bed Rug to attach the bed rug. I trimmed out the area for my pop up gooseneck ball and the U bolts. The rug was a tad short until you have a bed rug tail gate rug. Closes up good.
Chuck
PAE
I just used a piece of old carpet (living room) over the line-x . roll it up, when hauling wood chips / dirt . LOT cheaper $$$$
Mine is short at the back but not front, Im sure it's to avoid the tailgate. I paid $99 I bought it at Venom Off Road 616-635-2519 in Grand Rapids MI. It is really nice, it has dimples on the back so it let's it air a little. It's over a spray in liner and keeps things put, plus my dogs love it. It's a good thick mat too.
I bought this one from summit racing. Westin Bed Mats 50-6145. it fit perfect and was $76 +8 for shipping
Fit was right on!
Scott
So are you saying this mat measures 6'7" front to back?
I just went out to the truck and the mat measures 6'6" it is 1 inch short of the tailgate. When I bought it and stuck it in the truck it fit better than expected for half of the price of the one from the dealer (msrp of $140 IIRC).
My wife has never complained about the lack of 1" ;)
Scott
I was told the all mat makers did not want to make a new mold for the new trucks just to make a mat 1" longer so they all just carried over the same part number and figured no one would notice it is an inch short. I think I will buy a 8' mat and cut it down to fit the box. I feel like it may move a bit after a while and with no front box wall to hold it steady it may shift around.
