Odd Question: How do you clean out the space between the grill and ra
So, that's it! As the picture below shows, I've got bugs and leaves stuck in that space and I can't figure out how to get it cleared out. Anyone have any tricks or ideas? Am I missing something obvious here? Much appreciated!
6380FAB3-A6C1-4306-8F51-5ECD904EFA7B_zps
The way I've accessed in the past is by taking off the grill.
Not the most fun task lol.
First you take off the cover that covers the grill and radiator. It's about a dozen of those plastic pop screws that can be remover by a flat head screwdriver.
Then you take off the trim piece below the grill. I believe the trim piece is (4) metric screws and then just plastic tabs.
Next to take off the grill, it's (8) metric screws and it will pop off. Viola, full access.
P.S. it gets easier with practice.... lol.
And those plastic pop rivets get looser and looser every time you fool with them?
Can you make compressed air work?
Mine haven't gotten any more loose. In the event that the did, or that you lost one, they sell them in the hardware sections of Lowe's and Home Depot.
Compressed air is a pretty good idea. Don't forget safety glasses in that case!! Lol
When I bought my truck I didn't notice that a bird's nest ended up in there for sitting on the lot. I couldn't use a shop vac because the end of the hose couldn't fit in the grille slot. Dealer ended up removing it for free.
Shop vac works for me but may be different for a Sierra. If the spaces in the grill are too small for the vac I would attach narrower flexible tubing to the hose of my vacuum.
Saws-all works more quicker'er (o:
Shoot, if we can color outside the lines, there are a number of things that might work. Drop some Black Cats down there - maybe a string - and see if you can explode the debris out!
A friend named Russell C. back when I was a kid, put an M80 in his toilet and flushed. It cracked the entire bowl. I bet that would work on acorns and butterfly wings!
Funny topic. I drive a lot of on the hwy, so I was accumulating a lot of debris behind the grille and starting to see damage to the coils from pebbles and such. Really no way to get in there also from the top. I used a 3' piece of 5/8" or 3/4" heater hose duct taped to my shop vac. Vacuumed it out and installed a Fia screen cover. 40k miles later, still clean and coil damage has stopped. I ran one of these fia screens on my F250 years ago and loved it back then. My mistake was not installing it the day I bought the truck new.
http://www.gofia.com/store/index.php?route=product/category&path=71_72
This is simple actually - just had the same problem with Monarchs during hunting season.
Pop the hood open, take the plastic cover off the top covering the grilles (2) bolts. Then remove the 2 bolts on top and pop the grille off with some pull.
I cleaned mine by hand (Don't use a pressure washer). Or even use a damp rag, took 2 minutes.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
