278,000 Mile Services
447,405 Km
11/18/2025
2015 Terrain 2.4
1K mile OCI
5 Quarts Mobil 1 Euro 0W40
No filter (2)
No longer tracking consumption.
  • 3 weeks later...
279,000 Mile Services
12/8/2025
2015 Terrain 2.4
1K mile OCI nominal
905 actual
5 Quarts Mobil 1 Euro 5W40
No filter (3)
Timing cover seal now leaking enough to wet the frame but not the ground. 😬
0W40 improved fuel economy.
Shorter than normal OCI as weather is play a part not in what Dizzy needs but in what I can do. Below freezing and now the next two days they are projecting rain then back to near zero until the Bears with a Superbowl. :crackup:
  • Thanks 1
On 12/13/2025 at 6:02 PM, OnTheReel said:
Somehow, some way…this person damn near doubled your mileage on this motor…IMG_4526.thumb.jpeg.0777c064d1250b41f0433f7828fa0df8.jpegIMG_4527.thumb.jpeg.e4cc3cb8a80ae09bd81b25b0f5b4555b.jpegIMG_4528.thumb.jpeg.fcf8d92b29ebdf99c2bb15fc6824af6b.jpeg
I've seen a few like that. Either multiple motors OR OTR long haul delivery. Crazy length for the that transmission. Would love to interview the owner(s). Absent context, it means little. Still, not matter how it was done...hat's off.
  • Like 3
Yeah, once they go to auction like that we really have no backstory. I’ve seen a few in the 300-400k range but half a million really got my attention. Even if they put a motor in it at some point (probably) they got their money’s worth outta that chassis.
  • Like 3
On 12/24/2025 at 2:31 PM, customboss said:
2 answers stood out to me from the mechanics answering the ?, the second guy when he said "well, none really" and the last guy that responded with the Willys/Ford made flathead 4. After my Dad was discharged from the army in 1946, he and his youngest brother started farming together. They picked up a war surplus Willy's made Jeep to tow a small service trailer that they had made to haul a diesel tank, compressed air, bulk grease and assorted grease guns, tools, and what have you. This Jeep I would surmise lived a pretty tough army life as the paint was faded from the time my Dad and Uncle picked it up and the exhaust system was basically nonexistent, about a foot of the exhaust pipe remained back from the manifold where it had been jaggedly broken off, and of course a leaky radiator. Even though it was only a 6V system, I don't recall it not ever starting, only gauge we payed any attention too was the temp gauge which topped out a 212F, if it started creeping up past 160F it was time to pull out the water jug and top off the radiator. 4WD p/u's weren't all that common until the 60's and although my Dad and Uncle got tired of backing that grease wagon trailer up, it wasn't until the 80's that they could justify the cost of a used 4WD p/u that was a dedicated use "trap wagon". They ended up finding a 3/4 ton 60's era cornbinder that was pretty indestructible in it's own right which they used until their retirement in the early 90's. My second cousin restored the Jeep to it's former glory, ready to be called on by the army again.
  • Thanks 1
Great little engine and very smart response.
  • 1 month later...
Breaking News
Fuel dilution has been a long standing issue with Dizzy. We've gone through two pumps and a rash of injectors and hinted at ring seal failure. We've also torn the fuel tank vent system apart multiple times replacing and testing until there is nothing left to test or replace. Multiple plug and coil replacements. Revamped the PCV system and yet dilution persisted. There has been a curious offset in fuel trims after fill-ups since we got the Liner Logic Scan Gauge II system sorted and programed. Like the EUC pulling up to 30% fuel for ten miles or so after a fill. And yes I'd stop after the first pump auto click. Dealer has not idea, I had no idea and my independent mechanic is scratching his head.
So......as I have a good grip on the amount of fuel used (Scan Gauge) I shorted a fill 2 gallons, lied to the Scan Gauge and then started filling whatever the Scan Gauge showed I used instead of filling to auto shut off. This placed the gauge on Full but started declining right away instead of consuming 2.5 gallons before coming off full. Pretty standard experience for most all cars/trucks.
Guess what? Fuel trims never go past -5% and go back to zero +/- 2 with in a mile, standard purge time.
That tells me that filling to the auto shut off in this vehicle was filling the carbon canister and flooding the vent system, dumping raw fuel to inlet. That is a design flaw. I have more that doubled the OCI before the oil gets inky and stinky. It's also tripled time between P420 codes.
Something I will make a practice with the Verano. Short filling. All of them actually.
281,463 Mile Service
Rotate and balance tires. A bit over my usual 5K. Weather and scheduling. But drives nice and straight. No worse for the wear.
282,000 Mile Service
453,835 Km
2/12/2026
3,000 mile OCI, 80 oz of make up oil. 1 quart/1,200 miles.
Rotate and balance tires. Nothing more than half an ounce required.
1 Purolator filter (red box)
Topped off Coolant. It's a winter thing.
Wiper fluid. Brake fluid check.
  • 2 months later...
285,000 Mile Service
458,663 Km
4/25/2026
3,000 mile OCI
3,080 actual
90 oz make up.
5 Quarts Valvoline R&P 5W30
1 Purolator L15436 filter
4/28/2026
285,135 miles. Tire rotation.
Edited by Grumpy Bear
  • 2 months later...
7/4/2026 Maintenance Update
I gave Jason a bit of a blank check (within reason). If you find something, fix it don't tell me about it (within reason).
AC clutch crapped out. I've been hearing if for near a year and milked for all it was worth. Used unit going in. We'll see on the belt and tensioner. We have an understanding on what this truck is and what I'm willing yet to do.
Added to the list I gave him. So far few surprises. Not much longer.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
