First time user bare with me, I have a 2011 chevy Silverado 5.3 engine has the 243 heads and I have low compression on cylinder 7 I removed my intake manifold and discovered quite a lot of gas in my cyl 7 port? Running a leak test tomorrow but has anyone had this problem I mean truck is 6 years old with 104k miles I'm 2nd owner but I'm hoping for a bad exhaust or intake valve I don't wanna replace piston rings anyways any ideas as what to also do or look for ? ( also when pulled valve cover cylinder 7 had a loose rocker pulled all rockers and pushrods seem to be all fine)
AFM lifter failure.
Chances are that the rings are fine.
Edited by muddkatt
The AFM lifters are 1,7,2,4. Chances are you could have a Lifter that is holding the valve open especially if it has come apart. Remove the 2 rocker arms on cylinder 7 and do a compression check again. If the compression returns to normal you have a faulty lifter. If it doesn't return to normal then do the leak down test.
Hey guys thanks for the reply your both right the lifter is bad and will be replacing all with original GM lifters now about this AFM I see a lot about it well a lot of bad and from what I see I can delete or turn off AFM ?
One more thing can I squirt WD 40 in cylinder bores and hold rag over and spray them out with air ? I don't wanna remove the pistons ?
Not understanding exactly what you are saying/asking.....
There is some grit in the cylinder bores above pistons they are all still in and I don't wanna force the grit down into the ring gaps but I don't wanna take pistons out what's a good way to clean them out without taking the pistons out
Wipe them out with a clean rag, then hit them with compressed air, then wipe them out again.
Yeah you can program the AFM out of it or you can replace the lifters with older model lifters but I believe you need to replace the valves and springs as well. I really dont remember it has been so long since I have done that,
OP, how did you know you had a problem? What was the truck doing?
Edited by txab
Slimjim2525 i was just going to park as I pulled into work and it started shaking in steering wheel and just missing out like it wasn't getting spark idling at 500 rpm like it was about to do finally check engine light started flashing and stabilitrak/service traction control was coming up on dash once I checked fuel injectors, new spark plugs put in, took a new coil pack around to all cylinders all of it never did a thing did compression test and it was very low cylinder 7 which is an AFM lifter and did leak down and then tore head off checked lifters sure enough 7 on intake side was collapsed
OK thanks. Mine has 132k miles on it and noticed recently when it goes into V4, there is a very slight vibration in the motor, then when I step on the gas and goes to V8 the vibration goes away. I just ordered the range disabler.
Well started assembly and the retainer bolt for the lifter tray is not tightening down I screwed it back out and had small thread shards spiraled on the bolt anyone know what tap size I should use obviously I'm going to have to go oversized, really don't know what to do ??
THIS POST IS FOR FUTURE VISITORS HERE THAT MAY HAVE THE SAME ISSUE.
I have this exact issue. My Sierra is a 2009 with 301,000 miles.
Started with a mis-fire in #7 and puffing some smoke. I did all the simple test to make sure I was getting spark. Did a compression check and 1,3&5 all had 160lbs and #7 was 0.
The needle didn't budge in the compression gauge which I thought was very odd. I pulled my valve cover off and redid the compression test. I was hoping to see air blow oil around the valve seats. However, what i saw was #7 Rocker wasn't moving. But what threw me was I could see the rod was actuating up and down. But, then I could see a good 3/8" of play between the rod and the rocker seat. These lifter have compression springs. I'm assuming my #7 intake has compressed and not returned.
I'm considering my options now. With 301K miles should I just replace the engine? I read some place that the kit to fix all of this may be $1100. (Crazy) the Ram dealer told me to buy that rocker, gaskets and a for sale sign. Then come trade it in.
If you think you have this same issue. Do your self a favor and take ten minutes and pull the valve cover. Look at the rockers. With the exhaust valve never opening there is NO air coming it to compress. Which is why the needle doesn't move.
"I assume that #7 has a serious vacuum on it and is sucking oil into the cylinder which is why I had oil on my #7 plug and puffing the smoke.
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
