TSB? No way as this is a safety issue. Tail lights are required and if there is a possibility that they fail due to crappy piss poor overseas inferior products due to cost savings attempts, then it will be a recall. If I had a light out because of this and the police pulled me over and gave me a ticket, I would force GM to pay for that ticket (if I had to keep driving waiting for a part).
GM has no shame in penalizing their vendors if they give them crap products for safety issues, even if it is their own fault for sourcing and not properly testing the products. Hopefully it becomes a lesson learned for them through this as every recall is a blemish and costs them potential buyers.
My '14 has already had 3 recalls and one item fixed for a TSB (which is now a recall). Pretty sad.
Yup just like I said a TSB. I can't tell you how many brake lights I see out on a regular basis. No recalls for them on a "required" item. There are 3 brake lights that are on the back of these trucks I bet it only needs 1 to be in working order to trigger a major safety problem it would have to be that none of them are working. Like it or not. GM would only fix your problem and tell you to pound sand on the traffic ticket.
Oh yeah I owned a 14 so I know what you mean by recalls.
Edited by Blue Sierra Owner
Did you take your truck to your dealership with a taillight not working and they sent you away?
Yes sir. State of Kentucky only requires 2 tail lights so even if I fought for a rental they would laugh at me and say I still have 3.
You shouldn't be so quick to offer up "opinions" as it provides false info to those that read these. Since you are from Atlanta, this is what is required for Georgia (pay close attention to point b);
O.C.G.A. § 40-8-26
GEORGIA CODE
Copyright 2016 by The State of Georgia
All rights reserved.
*** Current Through the 2016 Regular Session ***
TITLE 40. MOTOR VEHICLES AND TRAFFIC
CHAPTER 8. EQUIPMENT AND INSPECTION OF MOTOR VEHICLES
ARTICLE 1. EQUIPMENT GENERALLY
PART 2. LIGHTING EQUIPMENT
O.C.G.A. § 40-8-26 (2016)
§ 40-8-26. Standards for brake lights and signal devices
(a) Any motor vehicle may be equipped and when required under this article shall be equipped with the following signal lights or devices:
(1) A brake light on the rear which shall emit a red light and which shall be actuated upon application of the service (foot) brake and which may but need not be incorporated with a taillight; and
(2) A light or lights or mechanical signal device capable of clearly indicating any intention to turn either to the right or to the left and which shall be visible from both the front and the rear.
(b) Every brake light shall be plainly visible and understandable from a distance of 300 feet to the rear both during normal sunlight and at nighttime, and every signal light or lights indicating intention to turn shall be visible and understandable during daytime and nighttime from a distance of 300 feet from both the front and the rear. When a vehicle is equipped with a brake light or other signal lights, such light or lights shall at all times be maintained in good working condition. No brake light or signal light shall project a glaring or dazzling light.
© All mechanical signal devices shall be self-illuminated when in use at the times mentioned in Code Section 40-8-20.
(d) All lenses on brake lights and signal devices shall be maintained in good repair and shall meet manufacturers' specifications.
HISTORY: Ga. L. 1953, Nov.-Dec. Sess., p. 556, § 112; Code 1933, § 68E-207, enacted by Ga. L. 1982, p. 165, § 4; Code 1981, § 40-8-26, enacted by Ga. L. 1982, p. 165, § 10.
Well, if that is the law, then what obligation do you think the OEM has?
Yup I fully understand the laws governing lights in Ga. I was a truck mechanic and driver for several years. There are several laws broken every day so I guess we are all law breakers? Do you always stay under the posted speed limit? I bet not. As for what I said. GM, Ford, Dodge, or any OEM you pick is going to repair the problem of an out of service break light if under warranty or you will have to pay to have it fixed if the warranty is expired. I also bet that their definition of an out of service break light also means any one of the ones on the rear are working is good until the problem is fixed. By the way Ga will only give you a "must be fixed" ticket and all you have to do is present that the issue is fixed and it will be taken care of.
There has to be moisture to rust. I used dielectric grease on my old Ram tail light connections. Haven't done it on my chevy but it is amazing stuff
That is the stuff we used on the trucks I used to work on. It works great!
This isn't a discussion on how we drive or choose to break laws. This is a safety item on a vehicle that GM has to address. Simple as that.
Ok you win have a nice day. Edited by Blue Sierra Owner
  • 2 years later...
GM definitely has a problem with their rear tail light bulb main sockets corroding.  I have a 2015 gmc sierra 2500 hd and i had issues with the right side turn signal main socket corroding and that was 3 years and 6 months after i bought it and of course the warranty had expired with 25,000 miles on it and dealership basically told me we can replace it for you cost of parts and labor, so I got a new left side wiring and connectors and did it myself part was around 75 dollars and took me about an hour to replace.  Now i am having the same issue a year and a half latter with the left side so another wiring harness and and another 70 bucks gone.  GM doesn't care about their product and i even went as far as filing a complaint with NHTSA, said they would look into it but never heard anything back.
Edited by Darrell Oinas
Right rear went first then left rear, i stated it backwards
I purchased my GMC Sierra in June of 215, by summer of 2017 the first light bulb went out. I should have looked in to it then but i did not. When several other bulbs went out in December of 2017 I took it to the dealer.  It was only 30 months old, but I had around 39,000 miles. They said it was not covered by warranty. I said this is really not millage related, that the corrosion for the Honduras made wiring harness was due to poor quality not millage.
They stilled did not cover it. I am always surprised how much money they spend marking to me, attempting to get me to buy a new truck. I purchase a new rear harness, bulbs and sockets. Replaced everything.  Well it is 5 years latter and now I am looking for a new truck. I have had 4 GMC trucks, I purchase a new truck every 5 to 7 years.  Time to give Ford a try.
Edited by TheFlagInspector
My 2017Silverado  had the same thing.  Upper passenger side had corrosion in it and didn't work.  35,500 miles and fixed under warranty.  Bill said they replaced harness.
Jim
    • That should answer the maximum depth difference between the stock and the PPE so its not hugely lower. As to the PML pan, they don't make any claims that it fits the L8T with the same transmission and in fact leave their information confusing, however on the surface it says "for Duramax" and so its hard to say. I know a while back and not sure which brand it was that specifically stated that the extra capacity pan that particular company made did NOT fit the gas version.
    • There are several versions of the 5100's. Some for stock height, some for leveled, some for lifted.    Side note. I finally had a chance to tow with my 30' gooseneck with about 10,000 lbs of material on it this past week. Hands down the 5100's made the trailer towing much more stable and comfortable. I even had 10 cmu blocks in the bed. What a difference over the stock shocks.
    • According to PML, the stock pan is 4.3" deep - (PML info): Dimensions: at deepest area, PML pan is 7 inches, stock pan is 4.3 inches    PPE is 5.4" so roughly 1.1" deeper than stock
    • I had not realized that PPE has come out with a version of a cast aluminum oil pan specific to being able to fit onto the 10L1000 with the L8T engine sometime this spring. I was doubting that anyone would come out with something beyond what Dorman had in more of a direct factory pan swap. I see from one comment that is on the PPE site that they found the pan to be tighter to install then the factory unit and having to flex the exhaust down to fit it. I didn't lookup any specs if they have any as per how much lower it hangs but as it holds more oil and has fins outside the pan it would no doubt hang a certain amount lower.    I looked back at the site and they do have some depth measurements to get a rough comparison to the factory pan total height or hang down if you will at the front and rear of the pan so that will give a good idea how much further down this pan would end up being for ground clearance issues.    2024-2026 GM 6.6L Gas 10L1000 Heavy-Duty Cast Transmission Pan – Pacific Performance Engineering
    • I'm in constant amazement over the number of people that do oil maintenance by how they feel, what they were told, what materials cost, what brand A claims vs brand B.     Come to think of it, this behavior isn't exclusive to oil. 🤔 They drive this way too. 😬   There is a 20 plus page thread on BITOG on Mobil 1 Advanced Clean vs Valvoline Restore and Protect it would be amusing if it were not so........humanly pitiful.   Last Sunday we were are sitting at services and listening to a speaker talk about Jesus parable of the wide and narrow gates and he said something that hadn't dawned on me but totally fit the way people in general are about just about everything. He said there are so few people on the narrow path leading to a good reward not because the the narrow gate was hidden or hard to find but because the wide gate leading to a bad end it so darn easy and uncomplicated to follow!!!
