Heads up display
If I understand correctly you need the Denali insturment cluster, the HUD unit, the Yukon wiring harness from the IC to the HUD unit, the dash panel/bezel, and HUD controller from a Yukon Denali.
Then you would have to get the HUD turned on in the instrument cluster through GTPprix. Lastly would be installing the HUD, dash panel/bezel, wire everything up with appropriate connectors, and come up with a way & place to mount the HUD controller.
My Denali has the front collision HUD, but that's all it shows, blinking red lights. Can't believe they didn't give it the other basic capabilities.
I owned a couple of Pontiacs with it, really liked having it and would pay extra for it in any vehicle that I could, but understand that it's expensive to design the dash to support it and at least on the Pontiacs, it required a special windshield with a polished flat are where it hit so those cost a little extra too (although I know people that replaced a cracked windshield with a normal one and couldn't tell the difference). Anyway, here's an aftermarket product that looks interesting, but I haven't pulled the trigger on it. Thought about though. https://www.navdy.com/
I'd much rather have this than my rear camera, tbh.
We need to find and review a schematic of the HUD system on a Yukon with it. That would tell us if it has its own fuse, relays, where the controller plugs into (the back of the instrument cluster, directly into the HUD unit, etc), whether the HUD receives power outside from the instrument cluster. We could also find out if there are dedicated wire harnesses, connector types/pins, etc... Without a schematic there is a lot of speculation.
  • 1 year later...
Same on my 2018 SLT. of course it’s available on the next gen 2019 trucks! I didn’t know the current SUVs had it until this thread.
