Anyone have a vibration in the floorboard at highway speeds?
FADEC
Have been noticing this on the last few road trips. It's a light tingling vibration in the floorboard that seems to present itself between about 1500-2200 rpm. It's most pronounced at around 1750 rpm which is where I'm usually at at interstate speeds.
After about two hours it starts to put my foot asleep. It feels like stepping on a jitter bug sander very lightly. A real high pitched tingly type feeling.
Will mention it at next oil change, but I'm sure I'll get the "they all do it" or "cannot duplicate" answer.
BTW 2016 5.3 8 speed crew cab 4x4.
Hello FADEC,
I can certainly understand your frustration with this situation. We want all of our customers to have a positive ownership experience, and we apologize for any feelings of dissatisfaction. Our team welcomes the opportunity to look into this matter further on our end. If interested, please send us a private message to with your VIN, current mileage, full contact information and name of involved dealership.
Regards,
Anthony
GM Customer Care
Hello FADEC,
Regards,
Anthony
GM Customer Care
Then provide solutions for our vibrating shit piles
Medical issues such as blood clots or pinched nerve ruled out?
Do you have it in auto 4wd? If so put it in 2wd and see if there is a difference. I accidentally drove around like that for a few days and was wondering wtf, I'm gonna have to take this thing in to get looked at. Then I noticed it was in auto 4wd.
My truck does this also . Is this normal ??
No medical issues that I'm aware of.
Truck is in 2wd. Really never use the auto 4x4
Wife in the passenger seat also feels the vibration.
It will also do it around town as the truck shifts through the rpm range.
Mine does something similar to that, a very faint rhythmic vibration at freeway speeds, I don't notice it unless I make a conscience effort, V4 or V8 makes no difference. Nothing in the gas pedal. My stock front Goodyear's aren't in the best condition, there are small chunks of rubber missing and uneven wear so I'm thinking tires or a slightly out of balance driveshaft. I'm not loosing any sleep over it.
    • Congratulations Isttype, on your gmc. Really like my 2024 2500hd sle doublecab now with 85,500 miles.  I checked the oil today at 4800 miles since last oil change and barely reading on the stick.  I don't care if GM says it's Acceptable adding a quart every 2000 miles because that is 100% BS, It is not a 1966 Harley Shovelhead! Sounds like it's setting up a future failure like I had with my 1500 6.2l. Other than oil consumption problems, I really like the 6.6l gas and 10 speed is really nice.  Towed a light 4000 pound trailer last week and averaged 14 mpg.  I was pretty impressive that a 7300 pound gas truck did 14mpg towing, Later-
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • I don't think you will need a split, separate product, etc., the OBD port should be able to deliver everything you need. Since your device would be plugged into it all the time, it wouldn't miss anything.    Hardware in this case will be the easiest part of your project - ELM 327 devices will already deliver all the data you need. Reporting/software is where your advantage/marketability is.
    • I do too. I’ll never be stuck again 😂
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
