Well starting about a month ago when locking the truck the horn "beep" will not work. This is specifically when you park, and hit the lock button twice you normally hear a beep. That beep. Sometimes it does, sometimes it does not work. Even when I hit the lock button repeatedly. Figured it was the remote battery. Bought a new battery and put it in, no help. Then I was on the market for chrome LTZ fobs, bought two off Ebay and had the local dealer program them. Figured that might fix it. Nope, even with the new LTZ remotes it's acting the same. No beep sometimes. So i've tried different remotes, batteries etc. What could be causing something like this?
I had this issue once and found my kids were not shutting their door all the way. I was going to say to check the DIC Options for the horn feedback but if it's intermittent, that's probably not the issue.
Edited by pgamboa
horn works fine. wondering if the horn itself is going bad though, not being very responsive to the short electrical bursts.
Edited by FL335i
I have had this same issue...my kids close the door and I would hit the lock button twice and no horn. So i walked around the truck open and closed all doors, hit the lock button twice more and it would beep at me. Next time when it doesn't beep at you, try going around and opening and closing all the doors again. In my crew cab, it is usually the back door on the drivers side, for some reason that door does not close very good.
I know the rear doors take some effort to close... I'm wondering if maybe a position switch is out of adjustment. Good places to start!
  • 3 years later...
I have the same exact issue happening on my ‘14 Silverado LTZ. Did you ever figure out the issue; and if so, what was the fix? I’ve had it looked at the dealership and they had no idea. Just threw a new horn at it in hopes it would fix it. It didn’t work.
My 14 Sierra SLE seems to do this sometimes.... Hope it not a computer issue or something big on the horizon.
Will check doors next time
22R
  • 2 years later...
22R
Any luck on determining what is causing this issue? My 2014 recently started doing the same thing. Thanks.
Still does it but has not created any sort of issue either.
Yotaman
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 705 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
