GM Extended Warranty
Are all dealers required to sell at the same price or can you shop around for the lowest price after the initial sell etc...?
The warranties typically cost more after you purchase the vehicle, especially as you put miles on it.
Actually, they don't.
Yes, the price is negotiable. Yes, you can shop around.
You can buy a warranty as long as your vehicle is still under factory bumper-to-bumper. (3/36)
I wait until I'm about to run out of warranty before buying one. It doesn't do much for you while you're under the factory warranty.
Pay cash and you can negotiate the price.
well put, and a great idea.
You can definitely shop around. I remember reading threads cross posted from the Vette forums that mentioned some dealer who was selling them cheaper than anyone around (remember, you can buy the warranty from any dealer). I bought mine around 35,860 after GM emailed me an offer of $83/month, $260 something upfront, with a zero dollar deductible. (Total cost was just under $1,800)- not bad for buying post-sale and at higher mileage in my opinion. Used it for the first time today and it covered my failed AC condenser and a faulty tailgate handle, no questions asked.
I bought mine when I signed the papers for the truck . He told me it would cost 1,700 for 3 / 36,000 mile warranty . I told him if he took it down to 1,400.00 he had a deal and he said ok . So yes it is negotiable . I keep getting cards in the mail from GM wanting me to get the extended warranty . ( Not sure why they don't know I already have it .) They want 99.00 down and 21 payments of 99.00 for the same warranty I have now . Which comes to well over 2,000.00 dollars . I have used it twice now and it has already paid for itself .
I negotiated the sell price on a 1 owner local trade. Prior to committing I asked what it would cost to run it through the CPO process. The reply was $499. I agreed to buy "if" they ran it through the process.
With this I get all the CPO benefits. Biggest being 1 extra year on the 100,000 mile powertrain and 12,000 bumper to bumper.
Not sure if this helps your case but it made me feel better about an already great truck. Also there was a promotion that ends today that was .9% financing for CPO vehicles which helped.
Had a dealer sell me GAP when I put down $20K...... Got that refunded when I realized it wasn't needed.
Extended warranties are along the same lines....... Not needed until after warranty expires - may never be needed.
I do usually get road hazard on tires - even that can be negotiated - Discount Tire will throw that or mount/balance in often if you balk on it.......
But nothing else do I get service plans on, appliances, autos, computers etc..........
:bs:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
