4 hours ago, B R A D said:
Were you able to remove the grill without removing the trim underneath?
He did this on his Silverado, which has a different front end than our Sierra's. You have to remove the trim piece between the bumper and grille in order to remove the bottom grille bolts. I just did this about a month ago, no way around it. There's a youtube video of a guy who was removing the grille and bumper on a 2016+ Sierra, search for it if you need help. He does a good job of explaining and showing how to remove that trim piece (it's a pain the first time you do it, but once you know how it's a breeze if you have to do it again).
Thanks! I have watched the YouTube video before and am not too excited about removing the trim piece. It looks flimsy and brittle but I'm sure it's probably tougher than it looks. I have new emblems to install and think I'm going to go ahead and buy a light bar and install while I have it apart.
Yeah if you're going to have all that apart for one thing, might as well install something else you want while you're in there. It's not a hard job to do, just tedious. Gotta remove the fan shield on top of your engine bay to start (lots of clips), then remove part of your wheel well trim (bolt and clip), then remove the trim piece (multiple tab points), then you can finally remove the grille bolts and take the grille off. Might as well clean off your radiator too while you have access.
As far as that trim piece it's got flex, but definitely not brittle or cheap feeling. Obviously you can't go nuts and yank the crap out of it, but don't be afraid to give it some muscle on the parts of the trim that are directly under the headlights. Once you reach the corner of the headlight closest to the grille, that's when you go under the truck to release the tabs from behind the trim piece. It's tight in there so you'll need a long flat head screwdriver to reach a few of the tabs. You can't muscle the tabs loose though, if you don't release them from behind you will break the tabs and have to buy a new trim piece. Just take your time and it'll go smoothly, good luck!
Without messing with the active shutters used an aluminum angle which I cut to fit and mounted two LED light bars with a factory switch.
D2BEB4D4-22D7-426B-AAAE-5A8C8D915954.thumb.jpeg.ebda52abd8b3d93ee78f9270d26fcdfb.jpeg2B918181-08E3-43DF-925C-76A1E7B2E10E.thumb.jpeg.8d8fcb5fda1fad553b6abf6ca149b009.jpegB1E85029-7ACF-4B8D-8B6C-B3863344982D.thumb.jpeg.521dee1e6b07798b3030e831fc2d6db2.jpeg
  • 5 months later...
I have recently put a 30" curved led light bar in the grill of my 2018 sierra, there wasn't much room to work with but it is able to be done if you aren't afraid of a little bit of trimming. What I had to do was remove the grill obviously, I then found you need to remove the two lower shutters (they just clip in then you bend them a little bit to get them out) I had to trim the middle shutter in half to fit the light bar. The middle on is the motorized one so you cant remove it or else the check engine light will come on (ask me how i know lol). I then found the mounts that are from the light bar fit perfectly on the grill where it seals to the shutters, it only needed about a 1/4" spacer to fit nicely on the second lower opening of the grill. I also had to trim the fins on the light bar itself to clear the post in the middle of the shutter. After all that it fit perfectly.
  • 6 months later...
2018S1erraElevation Is that mounted directly to your grille? I'm thinking this may work with my lightbar.
Edited by Lnafree
Look's good - is that a 20" and 31" light bar ??? Thanks
4 hours ago, jaxsilverfox said:
It’s a 32” and 22” light bar.
Look's good - Any info on your light bar's ??? Thanks
Man I feel for you guys. Install on my 2015 was a piece of cake. Just made a couple brackets that bolt on to the rad support, filed a 1/4" out of my grille where the corners of the bar meet so I could push it out as far as possible. Active shutters, really GM? We made it 100 years of Chevrolet with no "active shutters", now they are necessary? Useless crap like this drives up the cost of these things for no reason at all. I have never had a cooling problem with a 1500 series truck besides burnt water pumps. How are these thin light bars, is the output the same as a standard style?
What brand are you bars ??? Thanks
JAXSILVER FOX  - Thank You for the info . Know to find a bar that will fit ? I try a 32" cruve  , put no go ??
Well I installed my 30 inch curved light bar with OEM off road light & harness. Active shutters are a PITA to work around. I didn't finish yet, I still need to trim grille & reinstall everything. The light bar has DRL in them which still need to be wired in. I took it out tonight to adjust the angle. For some reason I got a check engine light because of the ambient temperature sensor & my truck says it -40°C..... Wtf??
I bought them on e bay, they are about the size of an I watch from the side and straight. They definitely provide light when needed.
A little late to the party, but I bought a Rough Country Mesh Grille with Light Bar (DRL option as well).  By installing this grille and Lightbar, I was able to add another light bar, behind the grille with numerous modifications to the inner grill lining, in order for everything to fit properly.
Thanks to the Harness Dr. - Phil
Gamboa for the off-road light harness
and Timkering Fox for the video.
You
Edited by HAWLURR
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
