Does anyone know a way to drop the volume of in-cab door chime on a 2015 Sierra? I don't want to simply unplug / fully disable, but man is that thing LOUD. Haven't tried to physically get to it yet, but the thought of wrapping in foam has crossed my mind as a possible solution.
If I'm ever talking on Bluetooth phone when forgetting seat belt, it nearly deafens whoever is on the other end of the call. Thanks!
~Vol
The touch screen lets your lower it......... I always set to not honk at me when locking - and lower the volumn on chimes etc..........
Edited by Krusty
Any idea which menu? I'm pretty familiar with the electronics and I don't recall ever seeing that option. Maybe I read right over it, or else it's an option in your 2017 Silverado NOT in my 2015 Sierra.
I remember seeing a chime volume in the settings somewhere. Mine is all the way off, but I still hear the chime, I don't think it adjusts the door open chime. Im not really sure what it adjusted.
Edited by SkiDooNick700
See "Vehicle Personalization" in your manual......... Page 5-50 in the 2015 manual... page 168 in the 2016 manual (more like page 161 in 2017 manual)............... I also have the radio start-up set low.......... Enough noise at work and everyday life !
:freak:
Edited by Krusty
You can also get rid of the annoying seat rattler and have it do just an audible alert.
At work right now, but I'll see if I can find it later this afternoon. Thanks for the tips. I'm gonna feel like a moron if it's in the settings and I just never saw it. Doh!
~Vol
I had the same concern with my '15. The chime control available on the vehicle DIC menu didn't fix the issue. My dealer was able to dial it down to a tolerable level.
I did find the setting, but it was already turned all the way down. I played with adjusting it both up & down but like SkiDoo, I couldn't tell that it was doing anything at all. There's another setting in the same area for auto mirror that I *think* is supposed to fold in the mirrors when parking. From what I can tell, toggling that setting on or off has no effect on anything either. Will have to read the TSB link when I have more time. Maybe there's a known firmware glitch where some of the electronic settings are being completely ignored?
I took my 2014 in last year because of the extremely loud door chime and the dealership did the TSB. It helped but didn't eliminate the problem. The first chime or two are still very loud but the last few get quieter the longer I let it chime. Mine was originally so loud it hurt my ears and that is saying a lot because I can't hear worth a damn from my dumb days in my youth when shooting guns and running equipment without proper hearing protection.
There have been many complaints about this (search the forums for other threads). Most of us have the volume turned all the down in the settings and had the TSB done and it's still too loud. I just ended up buying one of these:
http://www.seatbeltextenderpros.com/gmc-sierra-seat-belt-extender/
Get the 3" rigid in the color to match your interior. Plug it in and leave it there and the seatbelt chime is gone!
Edited by sk
Until I had mine turned down by the dealer, I tried to remember to snap my seatbelt prior to stating the truck. I don't like to defeat any warning signals and was glad my dealer was able to repair this issue.
Oddly enough, I already have a couple of those from the exact same vendor! Mine are currently in the back. My kids are still in booster seats, and the extenders make it much easier for them to get buckled. As luck would have it, my daughter just crossed the age where she no longer needs the booster, so I may be able to relocate the extender. Great idea. Hadn't even thought about that.
Has anyone fiddled with the chime module itself (or is it even reachable without major dashboard teardown)? I'm still thinking about a good foam wrap. Also wondered if a resistor could be spliced into one of the feed lines. The mechanical engineer in me refuses to give up. :)
Did you ask your local gm service department if they can turn down your seatbelt chime?
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
