To remove the rubber pad, you have to access the bezel screws from the underside.
The cover pulls off with a trim removal tool. Then the charger unit, which is held on by 4 screws must come off to access these 7 screws.
Great thanks
Edit: wrong quote
Edited by 8lugmafia
Thats not true at all. just pull it off. takes 5 seconds
Mine would not. It was too tight against the bezel. Rather than risk breakage, I just pulled it apart. Took less than 5 minutes.
I took the underside apart too. Took no more than 5 minutes and didn't have to worry about breaking anything.
2 hours ago, Nick The Great said:
Does anyone know if the rubber tray is any wider in the 18's vs the 17's?
That's half the problem, the tray is not wide enough for my S7 Edge with case.  Barely wide enough without the case.
Another 1/16" of width would be fantastic
It should not matter if it is wider or not. I believe the problem may lie within the S7 itself. I have the Samsung Note 8 and I do not have any issues wirelessly charging. I even did a write up about it:
Even though it fits my Note 8 does not charge at all on my 16 Sierra All terrain SLT but my S6 edge charges just fine.
I tried to open and read that but it says the page don't exist ?
That's weird. I didn't remove it and I can get in it.
Did you modify your trim? I had to modify mine just so it could sit on the lip of the rubber mat. I also rotated my rubber mat.
No I didn't modify, my note 8 without any case fits but won't charge ?
How did you modify the trim ?
the note 8 will charge if you rotate the mat. My note 5 didnt charge until i rotated the mat either
O.k thank you
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,407 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
