I tried my new iPhone X tonight.  Could not get it to work.
Did you do the rubber mat rotated 180° mod?
No I haven’t rotated it. I thought about pulling off the rubber piece to see if it is an issue of placement.  I might try that.
Here you go -- don't waste your time...
https://support.apple.com/en-us/HT208148
That is why we have been asking if we can get updated chargers or console lids from the 2018 model trucks.
Edited by JacobC1983
Yes I saw that. It does not explain why though. It may be as simple as a placement issue.  Apple does not say what part of the Qi spec is not followed by GM. I know it is a long shot but I figured I would give it a try.
I found it somewhere.. I can't seem to find it now... if I remember correctly it has to do with the difference in wattage output in 2017 and lower model year vehicles; the iphone x requires a higher input wattage to start and maintain the charging process.  After you go through all the trouble, you will get the iphone x to connect for a few seconds and then disconnect and it won't continue charging.
Best of luck, though.  If you get different results please report back!
Ah, dang you went further than I did.  I will probably still give it a shot.  Last night I couldn’t even get it to start charging.
Thanks.
Dang. Good to know though.  Currently I have an S6 with an otterbox case, which is too big for the mat as others have pointed out. However, the phone is due for a replacement.
Def interested in a lid mod and/or software update that will look ok.
From what I can ascertain, the lids are the same. The charger bezels are the same, but the rubber insert, and the charger itself is different. I have the VIN from a friends 2018, and I plan to see if I can get some part numbers and prices for the 2018 specific charger and rubber pad. Not sure if the charger will be compatible with the 2017 truck.
In my console take apart and observation, the charger itself needs a Battery Positive Voltage and Ground. I would imagine the lids being physically the same, we could potentially swap the actual charger itself. I know similar mods actually do this using the same incoming power voltage.
Also curious on part #s.
I have a mount for my phone and cable but it be nice to extend the charging lid feature to my passenger.
Yeah i took it apart and tried it with my iPhone X. I was wondering if distance from the charger was an issue.  Still didn’t work.
The 2018 works just fine with my iPhone X.  I just went to the dealership and tested it out.  I got the part number for the 2018 wireless charger module which is 13507652.  The parts guy said that it only stated model year 2018 for that part.  He also said that it is so new that there is no price in the system for it yet either.
  • Like 3
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
