2016 escalade illuminated door handles
anybody have any reason to believe that escalade door handles will not be compatible with the K2s like they have in previous gen trucks and SUVs? thinking about ordering a set but wanted to put this feeler out first.
  • Replies 43
Best bet would be to see one in person I think to see if they physically fit.
They fit. There's a guy in the vehicle build thread that has white Denali handles on his. The lights and push button won't work though.
just add the photo from the site to make it easy, geez. too much clicking around as it is these days, that website is slow as balls
71309-fc9a68a07f224ff43ffb219c3c16fc4d.j
haha, yeah, the site has gotten slower over the past year or so. i'm wondering if they're on an old version or something?
i mean if you can get them to light up... even without the push button working, still would be a sick mod..... i thought i read somewhere they tapped into the puddle lights.... maybe it was the other thread.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 534 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
