New member with a GMC Sierra
Hey guys. Just bought a 2013 Sierra 5.3 crew Z71 with 95k on it. Love the truck! Unfortunately I have had to add 2 quarts of oil in the last 3k miles though. Seems to idle rough too. No check engine lights. Brought it to the dealer today and they changed the oil and started an oil consumption test. The service advisor told me that all the 5.3s use alot of oil though and GM wouldn't do anything. This true? Seems like a lot of oil for a $25k truck I mean I just bought it. My 89 F250 351 with 250k doesn't use oil at all. Doesn't seem normal to me.
Thank you. I read through some of it. Sounds like they will put new piston rings on it hopefully. Why would my service guy tell me they wouldn't do anything? They are reembursed by GM right? Maybe I need to see another dealer after the oil consumption test is completed.
You still have power train left right?
Just curious is all.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
