Pros vs Cons - The Range AFM
Thanks for all the info. Is the hypertech system good?
It's a tune, so your drivetrain warranty will be in jeopardy
  • Replies 40
wow the crappy Range is still tripping warning messages. I couldn't stand that on my 2014, had to take to dealer to clear the message. I went full tune and never looked back. I wouldn't waste any money on the Range product.
Hypertech is good, tried one at first, but now I'm using Diablosport I2 and feel more of a difference vs. Hypertech.
Yah, from what I understand, there really isn't s tuner yet for the '17.... Think I saw a couple threads on here somewhere.
Plus you're taking chances with your warranty if something does happen from your tune. I know they have to prove it, but not all shops are friendly.. :)
Sent from my XT1575 using Tapatalk
Hypertech Max Energy installed on '15. I've tried both the 92 octane tune and the regular fuel tune, 92 octane fuel may have been a tad quicker at WOT in the upper rpms, wasn't worth having to run premium fuel (JMHO). I think any tuner is going to accomplish a very limited seat of the pants feel in a 6000# truck. What I do like are the trans shift points and firmness adjustments as well as recalibrate tire diameter as well as ability to turn off AFM. My '15 has the 87 octane tune, stock shift points, +25% firmness, AFM disabled and tire size adjusted for 32" (275/65/18).
Well, it looks like I am now a Range AFM beta tester for the 2017 version. I'll let you know how it goes.
2017 Silverado 1500 Z71 4x4 Regular Cab Short Bed
Beta version is a no go. Took a few drives and the message is back.
That sucks....
Sent from my SM-T810 using Tapatalk
That sucks....
I'm gonna keep testing it and report back to them. Hopefully that can help them fix it.
As far as I understand there's a lot of misinformation in this thread.
If you use a tuner such as diablo sport or EFI Live (black bear peformance), both claim there is no evidence that flash count or other way to identify any tampering/tuning if you flash stock files before bringing back to a dealer.
BBP does a great job tuning 2017's.
Your taking a very small risk with a typical tune.
Quite different if your going for a 700hp+ supercharged build or something:
If your not comfortable then don't do it.
From what I understand, the Range claims it isn't suppose to write/alter anything either, but my report when I brought mine in to clear the reduced steering assist warning, the dealer wrote down, multiple codes in modules. Didn't list what the codes were and what modules, but it would seem, the Range ended up throwing codes, but didn't turn my CEL on....
When that key word, "claim", by EFI/Diablo turns into "guarantee", then spending that amount for a tuner will hurt less.. :D and that was one thing I really wanted from the tuner, the ability to undo the tunes if needing to bring it in for service and not worry about tripping something they can see to screw you out of warranty coverage. Some shops can be a pain.
That's the problem, there's always a small risk, depending on the dealer I guess. The dealer I go to seems ok for now. It's not the comfort level, it's, is turning off the AFM before warranty runs out worth it or not. It's not like every truck with AFM is biting the dirt.
I'd rather do a tune then use a bandaid AFM, but at the time I was looking, there were no tuner available for the 2017, just like Range didn't quite have a working firmware.
I've been using M5 around town and then letting V4 kick in on freeway/interstate runs, which is not that often.
Their lying
Their lying
There is a huge thread debating it that spans many pages.
But having read it all as far as I am aware there has not been a single instance that someone was actually denied warranty coverage due to a tune being detected if following procedure.
Feel free to send an email to bbp if you have any questions, very knowledgeable and helpful people.
Like I said though if not comfortable don't do it. :)
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
