Electric Vehicle
I hope this is the right place to post this; if not, my apologies.
I have a 2015 Silverado currently, but have been toying at buying an additional vehicle, as I drive lots for work. I've always been curious about the Chevy Volt/Bolt. One question I have is what kind of charger does it come with? I live in a condo, and installing a permanent charging station is out of the question. Is it possible to plug it into a regular wall socket? Obviously this would be much slower. The plus side is I'd be using this mostly for work, and most locations I go to have actual charging stations where I'd plug in. But don't want to be stuck if I do need to charge it, even partially, at home.
Any insight would be appreciated. Thanks very much.
It's likely you'll be able to search the vehicle data and/or ask the dealer about charge rates. You'll need to tell them residential (115v) circuit at either 20a or 15a (most likely). Does the car derate the amperage draw coming in (say, 80% max of available amps on a 15a circuit would deliver 12a)?
Then ask if the GFCI would be a problem (it frequently is with Tesla, but they're NOT the same as all the other PEVs out there). May not be an issue.
The question you need to answer is how many range-miles/hour of charging will be available for the duration you have it plugged in at home?
It's really cool. It's really efficient/inexpensive to operate. The $7500 Federal tax credit is starting to wind down...
Hope this helps.
Hope this helps.
Thanks for the info. I didn't know there was a Federal credit for it; I was aware of a provincial one ($5,000 in BC). Most of the time it wouldn't be plugged in at home; it would be charging more at work. Luckily there's charging stations all over the place where I live. Plus the Volt has a gas engine as well, so I'm less concerned versus a fully electric car.
I'm caught on how efficient these are to operate, so that's why I'm looking more into it. May be worth a trip to the dealership who would know of all the incentives and such as well.
Appreciate your info!
You're welcome.
1st, I didn't pay attention, even as I've seen your "name" a bunch. For me, Federal is US$ credit. Sorry.
2nd, I missed the hybrid part (though I have driven the Volt a few times.). My error.
"PEV" is plug-in electric vehicle.
So for PEVs all that info above is applicable.
I'm going to bed. Goodnight everybody.
I took a volt from work for a couple days, you can plug it into the wall and it's only electric for the first 77km (distance not speed) don't know about any of your other questions.
If your drive is far everyday, they sell a Cruze diesel and I believe that it is 52 miles per the gallon.
I haven't driven on but it sounds good.
You're welcome.
No problem. I initially read your location as "Mississauga" so I thought you were from Canada lol
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
