16 silverado Toyo RT
I have been looking around trying to decide on what size tires to buy. I can't seem to find a good answer to what the biggest size tire I can fit without rubbing. I found a lot of info for the 4x4 trucks but not sure if I have less room on my 2WD. I have a 2016 silverado 2WD custom with factory 20's. It also has a 2" rough country bottom strut spacer. I decided on the Toyo RT tire. Here are the sizes they offer https://www.toyotires.com/tire/pattern/open-country-rt-on-off-road-rugged-terrain-tires
If anyone is running this tire on a 2WD, any help is appreciated.
Different brand but I was running 275/65r20s with no rubbing on a 2.5 leveling kit. Skinny tall tire
I don't run a 20" rim but I do run R/T's. They can hold up to 80 psi which is more than most tires . Which imo makes them a little taller which can rub. I have 295/70R17 and they rub at full turn at about 65psi. Just my imput.
Sent from my SM-G955U using Tapatalk
