2017 GMC Sierra 1500 Denali Steering Wheel Canted?
Hi guys
Quick question. I recently purchased a 2017 Sierra 1500 denali and had a question about the steering wheel. This is my 3rd GM truck in the last 7 years and the first Ive noticed.
My steering wheel is not parallel to the driver seat. It is slightly tilted as though the shaft going to the power steering box is located in the center of the truck vs directly perpendicular to the driver. If you look at it from the top down, the steering wheel looks closer to the dash on the drivers side of the wheel vs. towards the center of the trucks. Hopefully I am explaining this correctly. I have measured as well and its definitely not parallel to the horizontal axis of the truck. Is everyone's like this? It was not like this on my 2015 Yukon or my 2012 Sierra.
Thanks
Hi guys
Thanks
I've driven 4 MY'16 and '17 trucks, including my own. All 4 that I've driven are like that. You aren't alone.
Pretty sure it's designed at an angle for impact safety reasons. So when it collapses in an impact the force is not transferred directly at you. The slight angle helps dissipate the impact.
That would make sense if there wasn't an airbag that impacted you, but that is not the reason. This issue has been pointed out by many of auto review sites. The reason the steering wheel is offset is because the steering column placement in our trucks are engineered to fit the steering shaft after the fact...otherwise laziness on behalf of the design team.
http://www.popularmechanics.com/cars/reviews/a9152/2014-gmc-sierra-1500-test-drive-15606695/
It's a GM thing.
Hasent GM been doing this for decades? My 1979 has the off centered steering wheel. Same with my 1997 and every other GM truck I have been in.
Wasn't it for ingress into the cab?
You've had 3 GM trucks and just now noticed it? Lol
My Yukon certainly was not canted. Cant say I remember on my older sierra. Its noticeable especially after you drive other cars. I noticed it when I first picked up my 17 sierra right after dropping off my yukon.
Maybe it is just more noticeable against a different dashboard. All my Avalanches and Silverado had this. Who cares? All that matters is that it steers properly.
No the driving experience is what made me catch it. Not looking at it from the dashboard perspective.
Refer to my original post, i wasnt sure if this was a defect or not. We've determined that it was common through the line. No need to be an a-hole about it.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
