2014 gmc blowing hot air
Most likely the controller for dual climate. Best way is to find one and swap it out to see.
Sent from my LG-H918 using Tapatalk
If it were the condenser (and it will be eventually) you wouldnt have cold at all. An acuator door is stuck or the motor is dead to the side with the warm air.
Absolutely the actuator door. You're looking $300+ if it's out of warranty for a dealer to fix, or about $50 if you do it yourself. Use to see this all the time when I worked in service dept for chevy
This went out on my avalanche one time, but it was the blower motor resistor module.
Dealer told me it is the blend door actuator, the dash has to be taken out to access/replace the part though. Not cheap to pay someone to do.
  • 3 weeks later...
Did you replace it? Im about to have to do this myself. Drivers side stays hot while the pass side is cold. Can anyone tell me where the drivers side actuator is located?
