Yes. There is a TSB for it. You will get a new exhaust system, then cross your fingers it doesn't make noise
TBS# please. i have a list started.....
Pi1201 Exhaust Rattle, Buzz, Pop or Whistle. March 2014
This was the original one I used but I'm sure it's been updated a few times and may have a new number
https://gm.oemdtc.com/7642/pi1201a-exhaust-rattle-buzz-pop-or-whistle-2014-chevrolet-silverado-gmc-sierra
I got a new design like the one that comes on the 2017 models in Feb 2017. So have them check for an updated tsb around Jan 2017
We traded my wife's 14 in on a 17 about a month ago. On the 14 I had the flapper valve removed after we had owned a while and within a week of picking up her 17 I drove it one day and had the valve removed on it. We both think the exhaust tone is a little deeper and have had no other issues with it. To me it was just a big restriction in the stock exhaust.
Would the dealership remove it, or do you have to get it done somewhere else??
I had a muffler shop do it. They cut the flapper valve out and put in a piece of pipe. I kept the valve but will probably throw it away at some point. Like I said in my earlier post, it is a big restriction in the system. They charged me $70 to do it.
Does anyone have the TSB info for the 2016 Silverados? Mine is doing the same chirping at 10,000 miles.
Check page 2 of this thread
I did, and that link says 2014 Silverado/Sierra
There is an updated one I think. Your dealer should be able to find it based on the link on page 2
Ok thanks, was wanting to get the TSB number just in case the dealer wanted to play dirty and say it was just normal noises.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 395 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
