Hillwood Posted December 29, 2018 Posted December 29, 2018 Go for the OEMs. Do yourself a favor on the fronts though. Don't use the stupid rivnut/nutsert thing they give you in the hardware pack for the front guards. Drill a few small pilot holes, go pick up some #8 or #10 by 3/4" black trim screws from the auto store, and self tap those into your pilot holes to secure the fronts. The rivnut requires a large hole, a special tool and is a bit more of a PITA. [emoji106]DILLY DILLY Sent from my SM-G965U using Tapatalk
ftwhite Posted December 29, 2018 Posted December 29, 2018 Weathertech on a 2018 1500 front and rear. Sent from my SM-G960U using Tapatalk
2018GMC Posted December 29, 2018 Posted December 29, 2018 I like the GM OEM front and rear flaps. They look great! I did NOT order the special tool for the front flaps. I drilled hole a bit smaller and gently tapped the nut in with hammer and some silicone around outside of nut. Flaps have been fine for the 1 year since I put them on.
StevenO Posted March 18, 2019 Posted March 18, 2019 Are the weather techs wider than the OEMs? My 2018 Denali came with Factory 22's with 285/50/R22 Nitto Ridge Grabbers and noticing the OEM's dont do a great job of preventing crap from being thrown down the side of the truck. It wouldn't take something a little wider to catch it all so I'm looking for a slightly wider option if there is one. Thanks,
spenpet Posted March 20, 2019 Posted March 20, 2019 On 3/18/2019 at 4:01 PM, StevenO said: Are the weather techs wider than the OEMs? My 2018 Denali came with Factory 22's with 285/50/R22 Nitto Ridge Grabbers and noticing the OEM's dont do a great job of preventing crap from being thrown down the side of the truck. It wouldn't take something a little wider to catch it all so I'm looking for a slightly wider option if there is one. Thanks, I do enough dirt roading that I wanted/needed flaps (I chose weather techs and really like them) but I don't do enough off-roading to justify a more expensive option...if I did, I would have went with the Duraflaps. they have a pretty solid design that helps shed dirt/water on the back side with grooves... https://duraflap.com/ at least an option to consider...(made in the USA)
J-rod_5114 Posted March 22, 2019 Posted March 22, 2019 I have a set of weather techs I had on my 14 for around a year for sale if anybody is looking
