1 hour ago, Raxnar said:
They are saying it needs a fuse greater than 20A, obviously this one you found for easy connecting is 50A.  Do you think this will still work for the Cellink Neo Battery?
I know, you probably aren't familiar with the battery product but you seem to know a bit more about electrical than I do.
Should I maybe put a 20A fuse between the spade connector and the battery?
Ya you can still use this spade terminal.  Fuse ratings are a capacity and the actual current going through the circuit is based on the loads that are connected to it.  So in theory since this device charges at 9A you could safely run 5 of these at once off that single point(which you wouldn't)
Yes, you absolutely should should go from that spade terminal to a Inline fuse.  I would also recommend trying to stick with the same kind of fuses the truck already uses(micro 2) so you can use the spares chevy conveniently provides in the case you end up blowing one.
Ideally fuses are chosen to protect a given wire size and the wire size is chosen based on the current the load is going to pull.  Usually for 20A you would want 12G or 14G wire.
  • Thanks 1
Thanks!  That is where my head was going and what I'll be doing.
The reason for the Cellink Neo is I had a Dashcam in my Subaru STI but it wouldn't last more than 30 minutes before it would shutdown due to low battery. Thinkware 750 with rear camera.
Now I have the F800 Pro and rear camera.  The Cellink Neo gives a couple days of parking recording if memory serves me.
So something like this would do the trick nicely.
https://www.amazon.ca/KOLACEN-Automotive-Truck-Holder-Pieces/dp/B07C5QK4LW/ref=sr_1_5?rps=1&ie=UTF8&qid=1528173445&sr=8-5&keywords=inline+fuse+14+awg
Again, thanks!
Again, thanks!
I'm sure the celllink neo will work out for you fine.  I just have a hard time wrapping my head around the price they want for it. Absolutely insane markup. Personally I would have a hard time justifying going that route when I could get a full size quality deep cycle battery and a battery isolator and run the entire truck on a dual battery setup and still end up cheaper than that thing with added benefits of having all the accessories battery backup-ed and having a extra battery  in case the primary starting battery goes dead.  Not to mention you end up with a 75-130AH+ battery instead of the little 6.5AH that the celllink offers.  You could probably have a shop install the dual battery setup with the parts and still end up cheaper than their asking for that thing...
most dashcams pull ~3-6W while fully powered on so that cellink with its 76W/H battery will probably only last 12-25 hours between starts.  The f800 does have shock activated parking mode which if you use that will probably last weeks though.
There are also battery drain protection devices out there that are only like 15-30$ that would also achieve what you want and always leave you with enough power to start the vehicle.
https://www.amazon.ca/Hardwire-Motorcycle-Charger-Cellphone-Protection/dp/B072J3L2JN/ref=sr_1_7?ie=UTF8&qid=1528181522&sr=8-7&keywords=micro2+fuse
https://www.amazon.ca/Blackvue-Power-Magic-Pro-Prevention/dp/B008B8ERIO/ref=sr_1_3?ie=UTF8&qid=1528182429&sr=8-3&keywords=power+magic
That inline fuse will work fine I used one exactly like it with a blue spade crimped on one end and a butt connector on the other side.
Just got my BlackVue DR900S-2CH with their ultra battery pack which will allow me full 24 hour recording without killing the battery.
Will instal after the lift this weekend and try to record the instal. Great set up - bran new cams.
I thought about the 2nd battery route myself and may eventually still do it. The special replacement cable is like $180 and a decent battery is about $200-250, so yes it is similar in price and offers more for the truck.
If I do the second battery I'll have the dealership do it to not void warranty, the truck is not even 2 months old.
I also had a $100 gift card to use at Blackboxmycar.ca so that helped :)
I looked at the Blackvue camera, couldn't justify the $200-300 price increase for 4k video only on the front. Other than that they are very comparable dash cams.
Blackvue have also degraded quality wise from the reviews I've read lately.
I hope you enjoy the camera though!
Degraded? From what I’ve read they went up since last model. They even went with a better newer compression. I could be wrong but I’m pretty sure they’re new one I’m getting(not sure if released yet) is much better than previous.
I hope that is the case and the reviews and Vendor recommendations are off.
Keep us updated on how it works out!
Will do man!
  • 4 weeks later...
Hi there.
I am working on almost the same thing, maybe I missed it in one of the posts.
Could I get clarification.
I have 2014 Sierra SLT. Putting in Vantrue x3 dashcam. Would like to hardwire from passenger fuse panel. Have a micro2 tap. Which fuse would be the always on fuse. All the short acronyms are confusing.
Thanks in advance.
  • 11 months later...
  • 1 year later...
On 9/18/2017 at 1:11 AM, Crazyjoker77 said:
I just hardwired my dash cam last week. In my truck there was no switched power in the passenger side only constant 12V. Drivers side has a dedicated stake for switched power (or RPO as chevy calls it) Just use a inline fuse with a standard female spade connector.
You will also find that mini add a fuse is useless as these trucks use a new standard in fuses called Micro2 (different from micro). I was unable to find a micro 2 add-a-circuit in any of the stores locally.
heres a picture showing the dedicated RPO power in the drivers side interior fuse box.(where the blue stak-on is) Alternatevly if you have to use a add-a-circuit that brown 7.5A fuse is also a switched source and is for the heated steering wheel that most trucks don't have but the fuse is always there.
Just to note, that 7.5 brown fuse supplies the steering wheel air bag coil as well. I'd use caution before tapping into it.
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
