2" Leveling Kit
What's everyone's thoughts on the Rough Country 2" Leveling Kit? Looking to just gain a little ground clearance. Other suggestions?
I just installed it on my 2017 with stamped steel control arms. The install was straightforward. Both sides took 1.5 hours. I had to remove the upper ball joint, and loosen the 3 upper strut nuts to be able to get the spacers in, and the bolts properly installed with the head facing up..
Read some of the threads on this topic then read some threads on Bilstein shocks. You may also want to look at discussions on lifts and/or strut replacements. There is a lot of good information on this forum so that you can make an informed decision. Sometimes there is a trade-off when you "improve" the looks. Trade-offs will be often be determined by how much you are willing to spend.
