Hey guys, do you know the part number for the nut that goes into the bolt for the transmission mount ? See picture for reference, ( where the hand is ) I need the nut that goes in this location. Don't know why but twice the nut has come off this mount, should I just use loctite on it when I put the nut in ( hehehe that's what she said ) or is there like an underlying issue I should be concerned about ?
Sent from my HTC 10 using Tapatalk
Ugh, guess I'll have to go to the dealer for this.
You'll need to pull the bolt to tell what size nut/threads.
part number for the nut #11516382
part number for the transmission mount #23134733
Loctite and look up the torque specs to ensure you are tightening it to spec.
Why are you concerned about having this repaired by your dealer? This is definitely a warranty item.
Don't have time to waste waiting in line at my local dealer.
It is sometimes  more expedient  to do simple repairs yourself,  but if nuts or bolts were falling from my vehicle I'd definitely have it thoroughly checked out by my dealership.  Warranties are to protect you from defects in parts and workmanship.  Having a service record of minor flaws could help in the future.
  • 4 years later...
Curious how you even noticed the nut was missing? Being up in the cross member like that, seems like you would have to be specifically looking for it to even notice?
no i was looking around for a grease fitting to lube on the driveshaft, and was checking for bushing wear on the tail shaft by pushing on the yoke and noticed the whole transmission was able to lift up off the isolator mount
this could be another reason why guys are blowing the driveshaft under load over 100 mph. look out..
Edited by pokismoki
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
