Zone 6.5 lift wheels
15z71
Just ordered some 35x12.50r20 tires and a zone 6.5" lift. I'm having a hard time deciding between 20x9 and 20x10. My understanding is the zone lift pushes the front out a little bit. Looking for some pics or recommendations on what width to go with.
post up some pics or any suggestions would be appreciated
20x9 +18 offset. I like the look of the 20x9, but it is all personal preference.
I appreciate it.
These are all I have on me at the moment. The back tires could be made to set even with the front if you added a 1.5" spacer, but it honestly hasn't bothered me like I thought it would. Sorry about the front wheel, it was kicked in a little when I took this photo.
Zone 4.5” with 33s and 22x10s
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
  • 1 year later...
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
